Boris, there are two electrical connector terminals which could be where the BFT cable can possibly be connected:
One is located to the immediate left of the slave cable receptacle on the top of the doghouse (passenger side). These two are found at the front end of doghouse, almost underneath the dash panel.
The other is located on the right rear vertical wall of the console, which sits on top of the doghouse. Again, there are two connectors, the power connector (closest to the rear of the console) and, to its right, another slave receptacle.
From what I've seen while going through all the HET-related TMs, there wouldn't be any hard connections with the wiring harnesses behind the dash or under the doghouse. The radio/BFT mounts are installed with rapid (relatively speaking) installation and removal. I know that was the case with primitive AN/GRC-160, RT-524 and KY-57 Vinson equipment inside our tracks, 5 ton trucks and jeeps back in the early 80s.
