‘Were the outer road wheels, on each track run, glued in place?’ ‘Could those road wheels have been removed allowing access to the inner road wheels for detail painting?
No, the wheels were constructed without glue, with the exception of seating the tracks closely around the sprockets with CA glue. I think it might be possible to remove the outer wheels for painting purposes, but notice in the photo further up, how these outer wheels also help attach and keep in place the tracks; so I wonder if it might be slightly risky in that it could disrupt their alignment - although it might not. From my own point of view, I have a few braille kits in various stages of completion, and would like to paint them with the tracks on, so I wanted to practice it here as I am convinced this is the way to go but haven't had much experience of it.
The tracks were sprayed with a mixture of Tamiya XF-52 Flat Earth and XF-69 NATO Black, and the wash was, I think, just very thinned Humbrol matt black. Actually, this created a bit of a problem in that I think the white spirit thinners slightly stressed the tracks. As with the similar styrene tracks that are used in the MPK Modellbau kits, the "joins" between the individual links are very thin, and the track
cracked just at the point under the last outer roadwheel on the right hand side - that's on the left of the second picture up in the post immediately above - and started to kind of uncurl itself from the idler. I had to use CA glue to re-join it.
Notice that I am taking my lead directly from Mig's FAQ on this part of the build (yes, I know he says it's obsolete, so let's call it a nostalgia trip...
something sandwiched between the clamps floating contact pad and the kit surface, what is it?
In fact that isn't to protect the detail from damage from the clamp, and you're right, the clamps are normally too harsh to use on anything with fine detail - so I only use them when it is something pretty flat, as is the case with the nose and underside of this Panther; anyway, it's blue tack and is in fact there to stop the clamp from sliding off the smooth shiny angled front of this tank - it's just enough to hold it in place.
So, I went to work to on that nose joint, including trying to obtain the characteristic welded joints. Then I masked off all of the tracks and wheels and touched up the primer, then sprayed overall with Tamiya Dark Yellow.
Then camouflage was sprayed on - I must admit I kind of look forward to doing this, and then get all nervous while actually doing it. I can spray fine on to my piece of test card, but when trying to spray on to the model, nothing comes out. This was made worse by my forgetting the need (in my view) to add a retarder to the Vallejo Model Air, with the result that at first, the acrylic paint sets on the needle / nozzle, so that you start to get bubbles backing up in the bowl. So, I emptied it all out, cleaned it, then re-filled the cup with 1 drop of Liquitex retarder to each 4 drops of the Model Air, after which it was fine. After the green, a little brown was added, sparingly, just
underlining a few of the green lines.
I think that the spray is a little unsubtle at this scale, in that even the finest edged spray looks a little out of scale; I had two bottles of Dark Yellow, one of which was very very thinned down with Tamiya thinners, but I had forgotten that it was the case. I accidentally used it to touch up a little green overspray around the turret rear hatch, and found that it actually had the effect of softening the sprayed camouflage stripes and making them look a bit more subdued and a little finer in appearance. So, some unhappy accidents, and a happier one.
Obviously this can all be re-touched a bit more when I remove the masking in order to add a little camouflage to the wheels.
Yes, I forgot... I used a quick coat of hairspray before the camouflage patches went on. This was to enable a few small chips / scratches here and there, which you can just about see, for example on the hatch edge. Oddly, it also produced the slightly discoloured, rough look to the Dark Yellow, which in the photos can be seen particularly on the side of the turret. At first I was a bit aghast, but then decided it kind of looked OK, so I'm living with it. Seemed to me that the Yellow was very matt which often seems to mean that it is slightly absorbent and hence susceptible to staining.
Another edit... ahem, also you might be able to see a bit of er... (bites lip) colour modulation going on.
