M998 with wooden box
casailor
KitMaker: 165 posts
Armorama: 97 posts
KitMaker: 165 posts
Armorama: 97 posts
Posted: Tuesday, June 25, 2013 - 09:09 AM UTC
When I was in EOD in the seventies we took a 1 1/2 ton trailer and converted it into a wooden incident command post. Mounted radios and field commo. We roofed it with plywood and then covered that with the original canvas cover glued into place.
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Tuesday, June 25, 2013 - 09:45 AM UTC
BruceJ8365
KitMaker: 441 posts
Armorama: 441 posts
Posted: Wednesday, June 26, 2013 - 01:03 AM UTC
MIG makes a wood pigment that seems to be the best thing I've found for wood.
I've seen oil paint artists use oils to get a real looking wood grain too... not just a "happy little tree" but wood panels as well by adding various colors on the brush and then letting it naturally streak with the brush strokes... this goes way beyond my abilities. I would have cheated and used a thin wood veneer.
Also note - that it wasn't uncommon to cover these wood structures with a tarp for protection (mostly in the European wet environments) and actually paint the tarps camo. I've done this on trailers before. Just covering the wood w wet glue tissue and paint, of course this negates the whole plywood look that drew you to this build in the first place.
henkp
KitMaker: 1,080 posts
Armorama: 1,064 posts
Posted: Wednesday, June 26, 2013 - 01:30 AM UTC
BruceJ8365
KitMaker: 441 posts
Armorama: 441 posts
Posted: Wednesday, June 26, 2013 - 04:31 AM UTC
Hey that looks awesome. WHat a great idea. Beats the hell out of messing with a bid sheet of veneer from Home Depot.
sampiero
KitMaker: 257 posts
Armorama: 250 posts
Posted: Wednesday, June 26, 2013 - 08:41 AM UTC
is an interesting information on this installation!
I repeat my question:
why build a case against in-plated cover with the original cover?
Is this a climate protection?
Is to protect the equipment EOD?
As they say in engineering :: "SOMETIMES DESTROY OFTEN BUILDING ALWAYS USE"
greeting
sampiero
KitMaker: 257 posts
Armorama: 250 posts
Posted: Wednesday, June 26, 2013 - 08:53 AM UTC
Thank you for these facts, I do not know that MIG was a wood pigment, for my part it was done with Humbrol and water. Then I work my colors by Reference to a piece of plywood against
greeting
sampiero
KitMaker: 257 posts
Armorama: 250 posts
Posted: Wednesday, June 26, 2013 - 09:06 AM UTC
Thank you! The info is good to know for the next challenge but if we knew everything, we would not try to do the impossible .... and as my uncle said Bonaparte "impossible is not French"
sampiero
KitMaker: 257 posts
Armorama: 250 posts
Posted: Friday, June 28, 2013 - 04:46 AM UTC
sampiero
KitMaker: 257 posts
Armorama: 250 posts
Posted: Tuesday, July 02, 2013 - 08:28 AM UTC
sampiero
KitMaker: 257 posts
Armorama: 250 posts
Posted: Friday, July 12, 2013 - 08:55 AM UTC
