@ AFV Bob , excellent , thanks for the info .
@ Panzerbob , hee hee.
But about guns -- earlier you mentioned the dummy main guns on the command tanks . This is to disguise them from the enemy ? ...I'd shoot at everything , so there !
My Big Box of Styrene has made it to Houston Fed Ex ! ( I'm just south )
It's scheduled for Monday delivery --- they need to get all those Christmas Gifts delivered first !
Oy!
Cheers ,
Just curious
Keith
Keith;
And you are RIGHT! "Shoot at everything". That's exactly what happened. Actually, worse yet, the first Befehlspanzer were those small, boxy modified Pz I-B - the SdKfz 265. Enemy AT gunners quickly figured out that the "odd guy on the field" was the guy to shoot at first!
The conundrum faced by the Germans (and by anyone else also wanting an armored front-line command vehicle) was needing to ensure command tanks received no more attention than any other tank, while still meeting the function, included bearing a unit commander and extra radios, etc.... A problem still current "in spades" with modern command vehicles.
The added radios, etc. take up room inside those cramped "Befehls" turrets. When these tanks became "Beobachtungspanzer" and / or FLIVO, the room problem got more critical, as the crew needed a chart-table for maps...
The first solution was that boxy -265 thing. But that looks special in the eyes of enemy gunners. Taking the main guns out of larger tanks met the room need, but made them look conspicuous and "special"... So, starting with Panzer III and seen in early Panther mods, a dummy main-gun was supplied so that things looked fairly "typical" from a distance. However, MOST BefehlsPanther and FLIVO-Panther were true gun-tanks- and just carried reduced ammo-loads to create functional space.
Interestingly, Dragon and CyberHobby put out kits of the prototype Panther D Befehls / Beobachtungs (CH white box) with dummy gun, and Panther G - Befehls with dummy gun (Dragon 9xxx series, I think). There was perhaps only one (1) D - Beobachtungs with dummy, and maybe only a handful of G Befehls with dummy actually made. MOST BefehlsPanther were gun tanks.
Cheers!
Bob
