BTW, do you use regular glue on the frame rails, or superglue? In fact, where would you use the CA glue? What type of bonding situation do you feel merits its use? What type of situation merits the Tenax 7R? What situation requires the use of that basic high school algebra? What situation demands voting Democrat? What situa.....SLAP!!!......sorry, got a little carried away there....
Tread.
I quickly slapped the frame back up on the alignment table for you again this evening alongside the longer M139 5-ton chassis. This one is slated for my Honest John Artillery Rocket Launcher. I was gluing some things and thought about your last post...
Here, I'm using 5-minute epoxy to set the rear dualie wheel hubs in place. The two sanding sticks again double as horizontal alignment jigs, while the grid paper helps to line things up from above - even when I don't always park the model spot-on for a picture
. I also parked two pieces of the Real Model M54 Cab Conversion (here virtually identical to AFV Club Deuce parts) on the frame for pre-spotting the placement of the cab against the measurements on the graph paper.
Amongst the glues you want to use, the 5-minute epoxy will give you a superior bond and a bit of working time before it sets. This allows you to spot-up parts like the wheels into the correct positions and alignments as needed.
The Tenax-7R comes in handy bonding the long sidewalls of the Cargo Bed. It isn't a strong bond, so if you've got some rough handling or sanding to do on those parts - get it done beforehand. Also, in the pictures above, I'm using .005 thousandth thickness sheet styrene on the cargo bed. To attach this to the model, I use superglue. Testors Liquid Cement and even Tenax-7R in some areas is too aggressive, and will melt the .005" styrene panels altogether. They really soften up the Italeri plastic, and make a real mess with delicate sheet styrene parts.
The frame subassembly is pretty much done with the Testors Liquid Cement, as this gives a strong bond and some working time to ensure things line up properly. However, for full-strength, I let the frame sit clamped into position overnight to let the bond cure. Epoxy is too messy and superglue too fast-setting for assembling the Italeri frame - as you need a medium amount of time to coax the parts to cooperate.
The superglue will come back into play assembling the resin Real Model Cab Conversion, or even in scratch-converting the AFV Club Deuce into a M54 Cab. It and the accelerator give a fast, quick, bond that doubles as a filler for bubbles and seams. I assembled both subassemblies solely with superglue and accelerator, and worked slowly to ensure I got everything in the right place before committing to glue.
Gunnie
P.S. - the time to vote Democrat is when all else fails, the skies are dark, and Liberace begins to sound really good to you...
P.S.S. - Algebra should be used everyday - and twice on Sundays in California. I did really well with Boolean Algebra in High School. Everyone who does, also does well in the Air Force. I wonder why? I also understand that Boojums are Snarks - but Snarks are not Boojums...
