Sorry but I can't help you with that Conrad. That is one of those angles that isn't ever really clearly in a photo.
Academy Magach 6B in progress
janwillem
KitMaker: 1,236 posts
Armorama: 700 posts
Posted: Tuesday, March 25, 2014 - 01:49 AM UTC
trakpin
KitMaker: 667 posts
Armorama: 639 posts
Posted: Tuesday, March 25, 2014 - 11:16 PM UTC
Very nice work, i myself am about to embark on building this kit, however after going through the instructions, the belly armour plates appear to come in 2 pieces, the sloped frontal bit for the lower glacis and the long rectangular piece that goes below the tank,just wondering if in reality these are 2 separate pieces or is it one single continuous piece that is fixed to the tank via the towing points. Can someone help me here? I've looked on the net but can't seem to find any reference of the area in question.
Conrad Choo
have a looksee thru here: http://www.idf-modelling.com/forum/viewtopic.php?f=2&t=149 lotta Gal Batash pix that might be of help, but I didn't see any from an underside angle. still the rest of the site might have something I missed
janwillem
Armorama: 700 posts
Posted: Sunday, March 30, 2014 - 04:33 AM UTC
Hi guys,
New update. The model got a filter, a wash and did the pin washing.
With this done I can start to add the dull coat. With the sheen gone I can finally really see the result of the black and white technique and the washes and filters and see if it was worth all the work.
JW
JW
pierric
KitMaker: 17 posts
Armorama: 17 posts
Posted: Sunday, March 30, 2014 - 07:41 AM UTC
I love !!!!!!
janwillem
Armorama: 700 posts
Posted: Sunday, April 06, 2014 - 03:35 AM UTC
He guys,
Dull coat went on and I started on the chipping.
I decided to go for a heavy ware and tare finish on this models trying to make it look like it has been used in urban operation's.
Some of the weathering might look a bit on the heavy side but there is going to be dust and rubble applied so that will tone it down.
I did the three dimensional method were you first paint on the scratch with a lighter shade of the base colour and follow that with a dark brown shade. In addition to painting on the scratches I also used the sponge technique.
In addition to that I added dark rust stains and some local washes and stains using AK interactive enamel products. And as always with photos I did see a few spots were the enamel products need some more blending.
I did paint the canvases but as it looks now I am not really happy with the result. I am going to wait until I have given it a dull coat to see if it improves or am going to redo them. Maybe a khaki brown colour.
Although it is not overly visible the black and white technique is showing through. This is most visible on the turrets sides. That only had the black and white, base colour and a general wash. So the variation in colour is due to that.
Still need to do a lot of small things (spare tracks, chipping the wheels, tow cables, etc.).
JW
JW
janwillem
Armorama: 700 posts
Posted: Monday, April 07, 2014 - 06:35 PM UTC
Well after the canvas had lost most of its shine I am going to repaint it. Going over reverences I am going to go for a shade that matches the vehicles colour (with maybe a bit of khaki added).
JW
JW
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Tuesday, April 08, 2014 - 06:09 AM UTC
Hi Jan until now you have done a good job.I'm following your progress with interest.
Cheers Luigi
Cheers Luigi
MadModeler
KitMaker: 454 posts
Armorama: 281 posts
Posted: Tuesday, April 08, 2014 - 10:57 PM UTC
Job well done so far. I'm impressed. Keep up the great work.
trakpin
KitMaker: 667 posts
Armorama: 639 posts
Posted: Thursday, April 10, 2014 - 11:34 PM UTC
lookin nice, altho to be expected. despite an odd quirk, academy has a decent kit. one thing I noticed is the right front fender. what are those strips? in Lt. Col. Mass's book on the Batash, some pix show it, but other tanks don't have them. also, the decals, and there's a yanush stripe along the gun tube top, are on a tank in the same book. tank Gimel, 2nd "Lahav" Co., 3rd Batt. apparently it was stationed in the Samaria region. it also doesn't have the side armor mounted, but the rear brackets are there looks like I'll have to change mine from 2nd batt. to 3rd also, the cover for the laser rangefinder housing is a split piece, but not equal in size.
if by chance you're a bit annoyed with that tiny hole in the outer box on the right rear fender, I cut a number tab off a sprue, cut it diagonally and wedged it in with a spot of glue. now it's no longer annoying, at least on mine
repynot
KitMaker: 194 posts
Armorama: 188 posts
Posted: Friday, April 11, 2014 - 12:16 AM UTC
I need to try this myself...
Just the white and black, WAUW!! It just needs a dirty wash and viola
@Russel:
There are no real other issues you should keep your eyes open for. You need to fill some holes and gaps but those are the same as with all the Academy M-60 kits.
As for the clearance issue, it is the bottom of the turret that catches. I don't have an issue with it and did not find it necessary to remove material from it to stop the catching. But that is a personal choice.
Back to the model.
I am using Jose Luis Lopez's black and whit pre shading/Lightening technique.
First I primed the model with grey followed by black. Then I airbrushed the white to the areas that catch the light and after that I used heavily thinned Vallejo black and white for the stripes and smears.
The idea is that the base colour that is going to be applied is very this so it will show through. If you get the chance you should check out Jose Luis Lopez's models, they are beautiful and inspirational
JW
janwillem
Armorama: 700 posts
Posted: Sunday, April 13, 2014 - 07:33 PM UTC
Hi Guys,
No progess this weekend. I got destracted by another project I am working on
@trakpin
From what I gather those strips on the front fender are for storing tents, tarps or nets and are not featured on all Magachs.
And as for that tiny hole in the outer box on the right rear fender, doesn't bother me
@Per
I really like this technique and am still figuring out how much or little base colour to add to get the desired effect.
@trakpin
@Per
trakpin
KitMaker: 667 posts
Armorama: 639 posts
Posted: Sunday, April 13, 2014 - 10:51 PM UTC
Hi Guys,
@trakpin
And as for that tiny hole in the outer box on the right rear fender, doesn't bother me![]()
@Per
yeah, found out what they're for after reading the captions in LtCol Mass's book. lotta dio ideas there, for those inclined
mogdude
KitMaker: 459 posts
Armorama: 195 posts
Posted: Sunday, April 13, 2014 - 11:23 PM UTC
Really like your work , How did you finish your tracks
janwillem
Armorama: 700 posts
Posted: Sunday, April 13, 2014 - 11:42 PM UTC
Thanks John,
The tracks are Friul white metal tracks.
They were treaded chemically to blacken them. The method I use for that is not one that is really healthy nor safe.
The solution that I use is a mix of bleach and vinegar that blackens the track but gives off very harmful fumes.
A safer way is to use Blacken-it.
When they are dry I gave them a heavy wash of raw umber.
janwillem
Armorama: 700 posts
Posted: Monday, April 21, 2014 - 02:37 AM UTC
Hi guys,
Well after 2 days of adding weathering to the model I am calling her done.
The figure is from Black dog with a Hornet head. Added the spare tracks, chains, cables and lenses.
I used Mig pigments, AK interactive earth enamels and various other finishing products to obtain the finish.
Going by reference photos of IDF vehicles in urban settings I kept the weathering light. I also added "stones" and broken bottles and cans as if the vehicle was attacked.
I know during urban operations the turret basket would be empty but that is a bit of the artistic licence.
A full build of the model will be featured in SMMI.
Hoop you like it.
JW
Hoop you like it.
JW
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Monday, April 21, 2014 - 06:03 AM UTC
Good job congratulations.Excellent details and a nice figure.
Cheers Luigi
Cheers Luigi
Posted: Monday, April 21, 2014 - 09:11 AM UTC
Great job looks good!
trakpin
KitMaker: 667 posts
Armorama: 639 posts
Posted: Monday, April 21, 2014 - 09:48 PM UTC
very nicely done
. looks pretty much like mine, except for the company chevron and turret basket. gotta ask, tho. what was used for the .50 mounting, other than the pedestal? what academy didn't seem accurate to me and the Batash book doesn't have a suitable closeup
janwillem
Armorama: 700 posts
Posted: Tuesday, April 22, 2014 - 01:03 AM UTC
Thanks guys.
@Trakpin.
For the .50 cal I used a mix of parts. The tan parts (pedestal) are from the Academy kit itself, the green parts (under the 50 cal and attached to the handels) are from the HobbyBoss Namer kit, the white resin parts ( ammo bin holder and shell bag) are from legend and the 50 cal is from another Academy set.
JW
@Trakpin.
JW
