Hi all. I know it has been awhile.
The gun and mount have been a task. I spent 2 hrs working with the PE slides for the bottom of the gun barrel. In the end I gave up. They were too small for my fingers and tweezers, and I could not get them to glue together, nor was I able to solder them. Old age sometimes creates its own problems in modeling….LOL
The solution I came up with was to carefully cut and sand down the parts from the kit gun barrel. This is probably not the best solution, but it worked for me.
I next began to assemble the gun mount. I had to be careful to continuously cross check both the Griffon and Dragon instruction sheets. If you don’t do this, I can guarantee you will miss something.
The assembly is pretty straight forward, but there is a lot of plastic removal to be replaced with PE. I try to stay about two steps ahead of where I am actually assembling, so I can anticipate any problems. This has saved my butt more than once.
The Dragon instructions are not easy to follow (big surprise there…LOL). There are parts that can be easily missed or mounted wrong if you are not careful. My advice is take your time when assembling the gun. It has taken me three days, but I feel I have a nice representation of the 75mm and mount.
Pictures of just the gun and mount.
Pictures of all three major sub assemblies dry fitted.
I am fabricating a gun pedestal for this build. The Ranger M3 was an early version of the M3 75mm GMC, and still had the AA 50cal mounted on a pedestal in the rear compartment. To do this, I am using plastic rod, a mount from the AFV Club LVT4 I just finished and sheet stock. The 50 cal is a combination of parts from Academy, Dragon, and Aber.
Next I will mount the rear storage bin, the 50 cal and the 75mm to the rear compartment. I still have the headlight guards and tools to prepare.
I should soon be ready for final assembly and base coating.
As always, your questions and comments are appreciated.
Dave B
