Ok, I have a confession to make; I've raced ahead on this build and am quite behind on my posts. Will do my best to catch up, as I've been taking photos along the way you won't have missed anything.
So, lets get on with it:
Front Glacis plate; Tamiya parts clean up well, will add some texture to cast parts in due course...
The Aber MG barrel looks great and was a pretty simple addition, the fluted barrel sleeve is so sharp - impossible to get in plastic.
The keen eyed amongst you (David) may notice I've removed the wingnuts for attaching the MG cover. These just don't look good moulded on in my opinion. I may scratch some '3D' versions if I fancy later on as I have plenty of PE wingnuts, but I don't know if by this point in the war they may have been removed anyway?
ouch. really 'chewed' out the initial style fenders as I'll show these missing showing some very aesthetically pleasing curved armour plate underneath.
However Tamiya was over-zealous in thinning out the mudguard area, so I had to thicken the corners of this area out to match the thickness of the rest of the glacis.
So thanks to David's great site it seems I need to change the front and rear hull towing points to a slightly different design that these initial tigers had.
At the rear, we have before:
and after:
They look ok to me, just ok though!
Note I have filler in that sinkmark in the side armour now.
At the front this is what Tamiya give you:
fine for a later (early) model, but not an initial, so I started by filling the towing eyes with some plastic rod so I can sand the areas down equally with the surrounding plastic. See Davids earlier pics for what I'm aiming for here.
So lets have a look at the picture so far:
Starting to take shape.
James
