Now I wish I had measured the fender at the same time!
Hi, All! Aren't we obsessing just a little bit over this? I've seen kits where the critics raved over them, and then finding out that there were obvious mistakes in those kits that went un-noticed by those same critics.
I really don't much care if a certain part is off by one or two millimeters- Obviously, HB got it wrong, quite badly this time, proving that it's bound to happen even in the most "state-of-the-art" kits anyway. Don't get me wrong... I LOVE the quality that we enjoy in most of today's kits, even if they ARE a millimeter or two off.
My solution? I'll keep using the old ITALERI/TESTORS 1/35 Water Tanker Jimmies for the hard cab versions, and make the required improvements. For an old kit, at least the ITALERI truck frames more accurate than TAMIYA's. Tamiya even excluded some of the steering assembly parts which ITALERI incudes in their Jimmies.
I like to use the TAMIYA tire/wheel assemblies, or resin versions w/snow chains. For the price of resin aftermarket cabs, I can BUY TWO ITALERI Water Tanker CCKW's... The cargo-bed tarps, unfortunately, can only be adapted with A LOT of filing and sanding, if you go the cheaper route and use the HELLER 1/35 CCKW's plastic tarp. I went that route with one of my TAMIYA Jimmies, and I also wound up having to file and sand down the TAMIYA stakes in order to be able to match up the fit and height of the HELLER tarp assembly. A LOT of trial and error, there...
In any case, I don't know if the HOBBY BOSS CCKW 352 Jimmy includes a plastic tarp, and if it does, then it would be much shorter because the CCKW 352 rode on a shorter chassis, with a correspondingly shorter cargo bed, thereby negating the use of an HB tarp with a TAMIYA or ITALERI CCKW 353. (SIGH...) I wish the kit manufacturers would pay a little bit more attention when producing 1/35 US AFV's and softskins...
