Auckland, New Zealand
KitMaker: 1,042 posts
Armorama: 871 posts
Posted: Thursday, October 30, 2014 - 08:19 PM UTC
KitMaker: 1,336 posts
Armorama: 1,137 posts
Posted: Friday, October 31, 2014 - 12:00 AM UTC
'stitched up' the welding nicely
Mitglied: East Mids Model Club Show: 24th March 2013
KitMaker: 857 posts
Armorama: 811 posts
Posted: Friday, October 31, 2014 - 12:48 AM UTC
Looks great! Outstanding work!
KitMaker: 1,866 posts
Armorama: 1,696 posts
Posted: Friday, October 31, 2014 - 03:18 AM UTC
Better be careful, Resi-cast will be wanting to break yours down into sub-assemblies to re-do theirs.....
Armorama: 871 posts
Posted: Friday, October 31, 2014 - 04:12 PM UTC
Armorama: 871 posts
Posted: Friday, October 31, 2014 - 04:49 PM UTC
The distinctive walkway along each side is provided as photoetch....
I soldered some brass rod to the underside to increase its rigidity. There are also two short lengths at either end which fit into two holes I've drilled in the superstructure to help with alignment....
And dry fitted....
Gary
Armorama: 871 posts
Posted: Saturday, November 01, 2014 - 01:41 PM UTC
Looking at some reference photos, it seems that the walkway support legs tended to have some strengthening ribs on the inner face so I added these using scrap PE...
Gary
Armorama: 871 posts
Posted: Saturday, November 01, 2014 - 02:46 PM UTC
The BARVs have some rope draped along each side and these are attached to rings welded to the edge of the upper hull. These are placed as per instructions before the walkway is secured in place....
Gary
KitMaker: 14,499 posts
Armorama: 11,675 posts
Posted: Saturday, November 01, 2014 - 10:44 PM UTC
Hi Gary,
Excellent work on the broken parts, resign doesn't bounce well, but your fix is excellent. Looking really good. The Archers weld strips look very handy, I have some but haven't used them yet. This will make for a really fine model when you're finished. Look forward to further developments.
Al
'Action this Day'
Winston Spencer Churchill
Myanmar
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Sunday, November 02, 2014 - 04:07 AM UTC
Excellent save after dropping the model. Your brass work and replaced weld beads improved it anyway.
i watched a scale plastic figure crawl along the edge . . . of an exacto blade . . . that's my dream , it's my nightmare . . . . . . . crawling , slithering . . . . . along the edge . . . . . . of an exacto . . . . . blade . . . . and surviving
Armorama: 871 posts
Posted: Sunday, November 02, 2014 - 08:14 PM UTC
Thanks guys
Crew access ladder. The sides are provided as PE with styrene rungs which I substituted for brass tubing so I could solder everything for strength....
Folds up when not in use....
Pulley. Needed a bit of clean up to remove excess resin but worth the extra work....
Gary
Armorama: 871 posts
Posted: Tuesday, November 04, 2014 - 05:51 AM UTC
Posted: Tuesday, November 04, 2014 - 06:21 AM UTC
Looking excellent, nice work.
Al
'Action this Day'
Posted: Tuesday, November 04, 2014 - 10:51 AM UTC
Gonna be a shame to paint it....
Ohio, United States
KitMaker: 731 posts
Armorama: 711 posts
Posted: Tuesday, November 04, 2014 - 01:24 PM UTC
Awesome build Gary! I have been following it from the beginning.
KitMaker: 3,770 posts
Armorama: 2,263 posts
Posted: Tuesday, November 04, 2014 - 02:06 PM UTC
Almost a shame to put paint on it.
Mike
Armorama: 871 posts
Posted: Tuesday, November 04, 2014 - 04:53 PM UTC
Thanks guys - glad you like it
PE chains with retaining pins added to appropriate places....
And this is where the fun really begins
Modelkasten's T49 steel tracks....
8 parts per link and 166 links needed :shock: That equates to a parts count higher than most complete kits
Not an evening build
Gary
Stockholm, Sweden
KitMaker: 444 posts
Armorama: 428 posts
Posted: Wednesday, November 05, 2014 - 08:04 PM UTC
Wow, master at work here. Very inspiring and a really interesting subject as well.
Seeing builds like this takes me closer and closer to try my hand at soldering
Armorama: 871 posts
Posted: Saturday, November 29, 2014 - 02:13 AM UTC
Thanks Johan.
I had a slight mishap with the tow bar so remade one from scratch...
Aside from the tracks, this is pretty much ready for paint now unless anyone spots something I've missed....
Gary
Armorama: 871 posts
Posted: Saturday, November 29, 2014 - 01:07 PM UTC
After a base coat of Tamiya Surface Primer from a rattle can - pretty important given the myriad of materials used here - I then set about the main colour. I gave this a lot of thought and even enlisted a RN model boat builder for some advice. In the end, I discovered I had the perfect colour already sitting on my shelf. AK Interactive's SLA Blue (AK-793)
After a nice spraying session and adding some colour modulation, here's where things currently sit (suspension units painted but not shown here)...
Next step will be to add a little gloss to where the decals will go. That in itself is a problem as most of the decals provided by Resicast are, in reality, unusable
I'm assuming there was an issue during the printing but they have small dots all over the artwork and look awful. The two circles with anchors are just about usable, but the AOS flashes and recognition stars aren't. The stars can be sourced from the spares box and I'll make the AOS ones up using suitable colour rectangles from spare decals.
Gary
Bergamo, Italy
KitMaker: 118 posts
Armorama: 112 posts
Posted: Saturday, November 29, 2014 - 02:50 PM UTC
Amazing job Gary
Very nice modulation.....are all BARV painted in blue?
I thought that these vehicles were painted in normal olive drab
Regards
Armorama: 871 posts
Posted: Saturday, November 29, 2014 - 10:32 PM UTC
Thanks Dario.
A vast majority were painted in 'Battleship Grey'. As they were used on the beaches, the colour was more suited to the grey seas. Some though were painted in OD and were used inland.
Gary
Moscow, Russia
KitMaker: 177 posts
Armorama: 177 posts
Posted: Saturday, November 29, 2014 - 11:58 PM UTC
Very impressive build!
Amazing detailing
Bergamo, Italy
KitMaker: 118 posts
Armorama: 112 posts
Posted: Sunday, November 30, 2014 - 12:46 AM UTC
Ok Gary, thanks for clarification
Armorama: 871 posts
Posted: Sunday, November 30, 2014 - 01:16 PM UTC
The idea of making the REME AOS flash out of scrap decals didn't work out as the red and blue bits I had started to break up when wet so that went straight out of the window
So out came the masking tape to do things the old fashioned way. After an initial blast with yellow....
While that was drying, the aerial recognition star was added....
Before completing the AOS flash with some Royal Blue and Red....
Have to say I'm pretty happy with the result. One more of these on the other side with two much smaller ones on each end....
Gary
