Hi Luigi, no problem, i made the same mistake.... But it was too late to remove. Great model you build here, verry impressive your scratch parts. Can't wait to see it painted. Work on a late Achzarit too.
Your Website is pretty cool, beautifull work there, like it.
Cheers Christoph
Achzarit
Lazzarus78
KitMaker: 75 posts
Armorama: 75 posts
Posted: Friday, April 10, 2015 - 11:18 PM UTC
llribera
KitMaker: 5 posts
Armorama: 5 posts
Posted: Tuesday, May 05, 2015 - 09:05 PM UTC
Magnificent piece, tell me where GOT WHERE PARTS OR MODIFIED could be acquired
THANK YOU
THANK YOU
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, May 08, 2015 - 10:05 PM UTC
I have scratch build some elements that I will use in the base which I will place the Achzarit.This is two elements of mobile barriers of containment in reinforced concrete present in many areas near borders of the Palestinian territories and a pylon for electric cables damaged.The first two elements they were built using as a basis of balsa wood 5 mm thick covered with ready mixed sealer-surfacer and further when dry sanded and engraved at various points to simulate wear while the pylon It was entirely scratch build with plasticard.
Photos on http://acciaioverdemodellingblog.blogspot.it/2015/05/achzarit-base-elements.html
Regards Luigi
Regards Luigi
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Thursday, May 28, 2015 - 04:44 PM UTC
I finished the background of the base for Achzarit and positioned the elements.Now I'll have to make the ground and start painting it all first the damage trellis and the two containment barriers.
More photos on http://acciaioverdemodellingblog.blogspot.it/2015/05/achzarit-base-in-progress-1.html
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Sunday, August 16, 2015 - 02:59 PM UTC
I almost finished the base which I will place the IDF ACHZARIT.I'll just give a little powder effect with the airbrush once I finished painting the vehicle.
More photos on http://acciaioverdemodellingblog.blogspot.it/2015/08/achzarit-base-completed.html
Ciao
Ciao
Rforand
KitMaker: 108 posts
Armorama: 89 posts
Posted: Sunday, August 16, 2015 - 03:28 PM UTC
Great work where can I find that fine copper wire used for tow cable tried Home Depot but no luck
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Sunday, August 16, 2015 - 03:38 PM UTC
Hi Bob the tow cable is home made done with six copper wires twisted with the drill.Thanks for your great comment!!!!
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Tuesday, September 01, 2015 - 05:31 PM UTC
I started painting the IDF ACHZARIT.After applying the primer I colored the entire vehicle with Humbrol 72 Matt Khaki Drill and color to dry I applied a second coat always with the same color mixed with 30% of Matt White only on the top of the vehicle.In this step,the color will be too light but after a few washes of the successive weathering steps that the vehicle will receive it will again have an appearance very similar to that of the initial paint coat.
http://acciaioverdemodellingblog.blogspot.it/2015/09/achzarit-paint-work-1.html
Best Regards
Best Regards
gilbertsakr
KitMaker: 310 posts
Armorama: 302 posts
Posted: Friday, October 02, 2015 - 10:11 PM UTC
super
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, November 20, 2015 - 06:58 PM UTC
In these days I started the weathering steps of IDF Achzarit starting from the bottom of the hull.Although not visible a finished model the work on this part of the vehicle allow me to test colors
and the techniques that I use in the next steps to finish all the work.Naturally being the part most exposed to degradation the weathering work It will be more pronounced starting with the chipping paint using Humbrol 88 Matt Chocolate.
http://acciaioverdemodellingblog.blogspot.it/2015/11/achzarit-paint-work-2.html
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, November 27, 2015 - 04:05 PM UTC
Weathering works continues on IDF ACHZARIT and I basically completed the lower area of the hull completing the phase of chipping and realizing the accumulations of mud and dust and with ground modeling and powder pastels of artist.Glazes clearer dust have been realized with oil color Yellow Ochre Pale.For sagging oil I used the product of AK Interactive Engine Oil while to reproduce the bare metal on edges and parts subject to friction, I used a pencil 6B.
More photos on http://acciaioverdemodellingblog.blogspot.it/2015/11/achzarit-paint-work-3.html
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, December 11, 2015 - 01:01 AM UTC
I finished washing on top of the hull I made with the oil color Raw Umber and after about half an hour removing excesses with a flat brush large base moistened with the diluent.The next step It will be to perform a slight Dry Brush with the base color lightened with white.
Photos on http://acciaioverdemodellingblog.blogspot.it/2015/12/achzarit-paint-work-4.html
Oddball007
KitMaker: 76 posts
Armorama: 70 posts
Posted: Friday, December 11, 2015 - 04:46 AM UTC
Outstanding workmanship Luigi, The Achzarit Looks great and the weathering awesome,
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, January 01, 2016 - 04:00 PM UTC
Paint work continues and post some pictures where you see the top of the model after the phase of the chipping and after the step of the weathering as an example of the various steps that I made and then over this operation I will paint the various details present on the vehicle.
Other photos on http://acciaioverdemodellingblog.blogspot.it/2016/01/achzarit-paint-work-5.html
Cheers and Happy New Year
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Sunday, May 08, 2016 - 01:58 PM UTC
Here are the new advances in the IDF ACHZARIT.I finished the hull and wheels.
More photos on http://acciaioverdemodellingblog.blogspot.it/2016/03/achzarit-paint-work-8-details.html
http://acciaioverdemodellingblog.blogspot.it/2016/03/achzarit-paint-work-7-tactical-signs.html
http://acciaioverdemodellingblog.blogspot.it/2016/05/achzarit-paint-work-9-wheels.html
Spartak
KitMaker: 130 posts
Armorama: 108 posts
Posted: Thursday, May 12, 2016 - 12:58 AM UTC
youngtiger1
KitMaker: 534 posts
Armorama: 344 posts
Posted: Friday, August 12, 2016 - 01:15 AM UTC
Just saw this thread and all I can say is...a bug WOW! This is looking awesome as the weathering on this is very realistic. Glad to see getting close to the finish line
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, March 03, 2017 - 03:16 PM UTC
Here are the photos of the IDF ACHZARIT finished and fixed on the base.This work took a long time but the end result has satisfied me.I wanted to represent this vehicle of the IDF during a patrol on the border of the Gaza Strip during Operation Protective Edge in 2014.
More photos on http://acciaioverdemodellingblog.blogspot.it/2017/03/achzarit-patrol-on-border-finished.html
flugwuzzi
KitMaker: 633 posts
Armorama: 599 posts
Posted: Friday, March 03, 2017 - 03:34 PM UTC
Excellent work. Great painting and weathering. The completed model and the base is top noch! Well done.
cheers
Walter
cheers
Walter
BroadSky
KitMaker: 37 posts
Armorama: 34 posts
Posted: Friday, March 03, 2017 - 05:02 PM UTC
Hi Luigi,
can it get any better?
NO!
This is absolutely fantastic! I love those beaten/worn IDF vehicles and you have done the best to represent that battle weary look!
I hope this won`t be your last IDF build.
Mark
NO!
Mark
Steven000
KitMaker: 191 posts
Armorama: 120 posts
Posted: Friday, March 03, 2017 - 05:09 PM UTC
Amazing work Luigi!
Looks very nice, great weathering!
Kind regards
Steven
Kind regards
Steven
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, March 03, 2017 - 05:10 PM UTC
Thank you Walter and Mark for ypur great comment and I hope to make other IDF vehicles.In my collection I have among others the M 113 Zelda,Merkava III and IV,Dr9 and more.These vehicles attract me a lot for their variety and use.Thanks again friends!!!!!!
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Friday, March 03, 2017 - 05:11 PM UTC
Thanks so much Steven!!!!
Ciao
Ciao
Keef1648
KitMaker: 1,240 posts
Armorama: 1,192 posts
Posted: Friday, March 03, 2017 - 07:06 PM UTC
An amazing job with great detail and composition.
Very inspiring to us all.
I will refer back to this when I dare to start building mine.
Thank you for sharing your build with us.
Keith
Keith
gigi63
KitMaker: 241 posts
Armorama: 241 posts
Posted: Saturday, March 04, 2017 - 08:57 PM UTC
Thank you so much Keith!!!!
Ciao
Ciao
