Pics are kind of scarce from the day.
It's not that bad. I have quite a few of pics from CAT87.
It's clear they had the gooseneck lifting fixture on the mantlet, but I've seem those on straight M1s also.
Really? I have never seen such combination.
Additionally, the definitely didn't have the spacer ring around the base of the barrel at the mantlet.
What spacer ring?... M1IP did not have any spacer ring around the base of the barrel. It only appeared on M1A1 with 120mm gun.
I was told by the tankers that those with the railings that didn't go back all the way were ones that were retrofitted and had original turrets and the ones with the railings went all they way to bustle were the ones from the factory with the added armor.
Nope. You can easily find evidence that early long turreted M1IPs had short railings and my photo above shows a rare case (a retrofit?) of the short turreted M1 with the long rainings.
I guess with such ambiguity about the issue, I can settle for using the old M1 as the base and reconcile any of my own doubt with it being something of a debate - hell, maybe there was even a mixture within the same unit as far as we know.
It is your model of course and you can do whatever you want with it.
