Hello again all
Thanks Mike, Jerry, Kurt & Alan for your feedback, appreciated guys!
Can't believe it's a month since I last posted, although it feels like I've been working on this forever..... The tree is now planted, the half track almost complete & 3 new figures have been added. Really pleased how the tree turned out. Wanted to avoid the full & heavy type of tree I've made in the past using steel wool as a 'blanket' for the leaves. This time wanted something abit more transparent. Basically it's made up of 3 parts for the branches:- a thicker twig for the main trunk with 2 or 3 main branches, thinner 'twigs' drilled & glued on to bulk it out more, with Seafoam glued to the very ends to simulate the fine branches. All this was airbrushed with a similar colour to the original tree trunk. Then the seafoam was sprayed with hair spray to act as a glue for the dried mint leaves, which were finely chopped even further & sprinkled over. These were sprayed with a dark green to give some contrast before finally adding a sprinkle of leaves from 'Noch'. Usually in the past I've not used these too often as they're really a bright light green when used 'en masse', but scattered more finely they're great.
Really happy with way the half track ended up, although I'm sure there's AFV people out there with a list of faults....
Respect to you guys who probably knock up these in an afternoon, this seemed to take me ages. Although I've been modelling for just over 10 years, this is only my 13th or 14th vehicle of any description, about 1 a year, so I'm still in the early stages.....
Problems with fitting the upper & lower compartments together, an over excited airbrush etc... Still need to add some pigments, stowage inside, paint the MG etc... It's going to be being unloaded by a couple of guys, should all fit into the space ok, hopefully.
Happy too with the figures. The guy on the bench is from Miniarts German Artillery Riders, with a new arm & Hornet head. He's a member of the Polish AK, wearing captured German uniform with a Home Army identification armband. He's reading a copy of the 'Ultimatum'(hence the title) that the German's have dropped urging the Polish people to surrender. This will be a theme throughout the dio. The 2 captured Germans are from Masterbox Panzergrenadiers, again with new arms & a head. Still another 4 figures to add in the cemetery.
Thanks as always for reading, any advice, comments & ideas welcome as always. Working on finishing the half track & fixing that on, the unloading, & the small steps area at the front. Have converted the woman from Masterboxs 'Resistance' set into something more suitable for the time. Will have her somewhere there with the 2 small boys, with some molotov cocktails in the mix....
Cheers for now,
SIMON.
