While examining the turret details of an M103A2 it is impossible not to notice the 120 mm main gun. The M58 was capable of firing Armour Piercing, High Explosive, HEAT, and White Phosphorus rounds. It was designed to reach out and touch the enemy whether it was long range or close in bunker busting.
The barrel in the Dragon kit is included as a one piece component. There are mould seams but these are easy enough to remove. There is no visible rifling in the barrel. Not too bad you say?
Well, this would be great if the barrel was the correct length.
I have read the review and accuracy analysis of the M103A1 kit authoured by Pawel Krupowicz in combination with the barrel measurements obtained by Robert Skipper. I decided to take my own measurements and threw into the mix the all metal one piece barrel made by Voyager Model in their detail set.
The measurements of the actual barrel portion of the Dragon barrel and the Voyager barrel are the same. But the muzzle and fume extractor of the Voyager Barrel is actually shorter than the kit barrel. This makes the overall length of the Voyager barrel even shorter than the Dragon Barrel.
Enter stage left the RB Models M58 three piece metal barrel. Based on measurements made by Robert Skipper of the real barrel and the same type of measurements on the RB Models barrel the results are essentially the same. This would indicate accuracy in the RB Models barrel.
End result...the Dragon barrel is too short. The Voyager Model barrel is even shorter. The RB Models barrel is just right.
Can the Dragon barrel be fixed? Sure, cut the barrel behind the fume extractor and at the angled collar. Source styrene tube the same diameter and cut it to 114 mm long. Glue the parts back together with the styrene tube in the middle and you should now have a barrel very close to the correct length.
The plus of this kit bashing is that you can increase the barrel length without much cost or effort. The downside is that styrene tube won't have a slight taper. But, neither does the Dragon barrel so you can decide what you can live with.
As the build continues I will demonstrate the kit barrel, the kit bashed longer barrel, the Voyager Models barrel, and the RB Models barrel all fitted to the turret.
Comparison image of the RB Models barrel (top), Voyager Models barrel (middle), and the Dragon barrel (bottom). Of note, the muzzle and fume extractor of the Dragon barrel is actually longer than the RB Models barrel. Go figure.
The RB Models barrel components.
The Dragon barrel and the increased length styrene tube to lengthen the kit barrel.
