Now I am by no means a tow cable aficionado but I have used my share of aftermarket tow cables and the string tow cables do not cut it. String tow cables do not seem limited to lower end kits but they are still common place in expensive well detailed kits and aftermarket conversions. Companies need to invest only a touch more effort and capital in order to get rid of the string and include copper tow cables.
I cut and sanded off the blobs of plastic on the tow cable ends and ditched the string. I replaced the string with the nicely braided copper tow cable provided in the Voyager Model M103A1 detail set. I drilled out the ends a bit to accept the copper cable before attaching it with CA glue. Within that set are also PE tow cable retaining brackets for the M103A1.
Upon reviewing my reference images I came to the conclusion that the M103A2 uses the same type of tow cable retaining brackets but they were moved to the sides of the turret and attached to a welded on base place instead of the previous hull sponson location on the M103A1.
I created a simple styrene base plate and attached them to the turret in alignment with reference placement. I then attached the PE brackets to the base plates.
Next I used the PE tow cable U shaped brackets from the Legend Productions M60A1/A3 detail set and attached them along the bottom edge of the turret.
Starting on the right side of the turret I attached the tow cable end to the bracket and added the hinged portion and wing nut PE parts.
I fed the tow cable around the turret and into the U shaped brackets. At each U shaped bracket I secured the tow cable with a touch of CA glue and created slight dips to add some variation as it travelled around the turret base. Once over to the left side of the turret the process was repeated to secure the tow cable end.
During this phase of the build I also added weld seams to the four turret lifting eyes and to the searchlight socket.
The result looks good and miles (or kilometres) ahead of what was provided in the kit.
I was surprised that the M103A2 had only a single tow cable given the massive size of the tank and other tanks such as the M48 and M60 had two tow cables.
