Construction of the track runs using my extremely hi tech jig....
First run complete....
Gary
End connectors and pins done....
Gary
Thanks Tom. I find that parts removal while being semi distracted by the TV really helps. End conector and pin assembly isn't too bad and using the wood jig makes fimnal assembly a real breeze![]()
Gary
[Why Bronco didn't mould the end connectors in place is beyond me.
More brackets added to the rear panel....
Hi Kurt
I utilised this walkaround - https://armorama.kitmaker.net//features/3960 - which only shows the lower 2 brackets along with the stowage bin mounts which I've added.
Does this mean those lower brackets are for the deflector? Easy to remove if not appropriate
Gary
Can't see the photos Kurt![]()
Gary
I'm still trying to find move definitive information on this early type. My biggest question remains the validity of the tow bar assembly as I can't find when this was introduced. More likely to be a post factory addition? It appears that some earlier turrets weren't fitted with footman loops so may end up removing them from my kit. I do need to add a fine casting line to the turret rear where the two halves join.
Quoted Text[Why Bronco didn't mould the end connectors in place is beyond me.
I think it would have made the molds very expensive if not impossible to make given the hollowed out end connectors and need to have very clean moldings for the pins.
KL
