Damn its been a while since I updated this!
Ever get a really bad case of modelers block? Yeah thats what I got around the last time I updated this. Looking back on it I think it came about for several reasons. Just prior to starting this build I'd kind of binged on US Army 1/72 helicopters and built and painted seven in rapid succession. Then I noticed my relatively new Iwata Neo had a bent needle and was going to need a new one. On top of that I'd noticed that the Bundeswehr figures I was planning to use on this build would need a decent bit of modification- not to mention the Aladin UAV (more on these later). Not insurmountable problems, just annoying and coupled with the fact I was quite busy in general and that in the first place I had started this build to get away from a rather protracted build requiring a good bit of scratch building and modification.
So this build went on hiatus until about last week- I was still checking out Armorama as I reckon, even when you've got modelers block, its good to see the great things others are up to and you also hope one of the fine builds here might give you the kick up the ass you need to get back to the bench.
But enough of that. I'd like to say a thank you to Hans-Hermann who, despite me not making any progress in this build, continued to send me references on the Fennek and UAV that are proving extremely helpful as I pick this build up again. I'll be sharing the cool stuff he's sent me as I go along.
I left off the last time having just painted the inner side doors green and was going to brush paint the detail and then weather them, so here they are.
The last thing I wanted to tackle on the Fennek was the tie down wires or the smoke grenade launchers at the rear. I'd kind of given up of finding a flexible wire small enough for this- until I was creating chin loops for the boonie hats on two of my figures- I was using stretched and curled sprue shavings that come up in the grooves of my drill bit when I am drilling down into them.
Once you stretch (gently) and twist (again, gently) these they get quite small and become like small wires- coiled yes but they look better than nothing.
So that was the Fennek all sorted and ready to get some primer. I set that aside and began working on the Blackdog figures and Aladin UAV.
I find Blackdog an infuriating company sometimes- they make some great stuff but also some turkeys (CHRISTMAS REFERENCE!) as well. Unfortunately this release is a bit of a turkey. First of all it was easy to mix both figures up once the mould blocks were cut off- they are pretty much identical apart from a slightly more pronounced arch in the back of one. Then arm attachment points are terrible so it took me a while to work out which arms went to which torso when I did mix them up. (In the box art you see that the guy holding up the G36K has some knee pads- but there were none present on my example).
Happily the arms didn't want to bond with CA glue either. I tried cleaning, sanding and a LOT of swearing but only one of the little resin gits actually attached properly. The others I had to use Magic Sculpt on- I would have to have got this out anyway to clean up the shoulder areas where the arms attached.
The soldier launching the UAV was the easiest one to sort out.
The head supplied was terrible so I replaced it with a Hornet one and a helmet from the Trumpeter Bundeswehr set.
Setting that figure aside I went to tackle the guy holding the G36K- not a great pose to be honest and one I had great difficulty getting to work alongside a decent Hornet head that showed him aiming/looking down the sight. I had to cut the left arm in half, pin both halves at a new angle and re-sculpt the middle. He was also missing his side arm but luckily there are a few extra in the Trumpeter set so one went one of those. His boonie hat also came from the Trumpeter set.
So that will do for now. Next up I will talk about the third figure and the UAV.
As always, thanks so much for reading. I wish you all a Merry Christmas- hope you all enjoy the holiday season!
