The U-shaped tow lugs are very brittle and will break. You should shave off the mounting nubs on their inner surfaces before attaching them. Otherwise, the slight outward bowing that would be required to attach them -- will break them.
Another enhancement isthe thickening up the armor slabs at the front of the drivers’ hoods using putty. The M4A4’s hood front faces have distinct bulges created by the casting process with the right bulge being thicker as evidenced by a deeper shadow in all photos. I simply applied a thicker coat of putty on the right hood than the left hood. You may ignore this if you plan on using the applique armor slabs. But I thought you might want to know.
