I am new to the site and have a question regarding static grass. I am looking to purchase some for a diorama I am working on. However, I am overwhelmed by the number of products available.
I was wondering if anybody had some suggestions regarding static grass. I am looking for a good quality product that is easy to apply and is realistic. Thank you for your help.
Shawn
Dioramas
Diorama-Static Grass Question
spstreeter
KitMaker: 37 posts
Armorama: 32 posts
Posted: Saturday, August 29, 2015 - 01:03 AM UTC
sdk10159
KitMaker: 556 posts
Armorama: 433 posts
Posted: Saturday, August 29, 2015 - 02:09 AM UTC
Hi Shawn,
Welcome to the site. YOu basically have two choices for static grass: Woodland Scenics and Heki Silfor.
YOu can usually find Woodland products in most hobby stores and Heki products I get online at
http://www.sceneryexpress.com/Static-Grass-Material/products/1230/
I have only used Woodlands static grass and I think it works well. I have used Heki/Silfor products, but not their static grass. Their other products are very good. BOth Woodlands and Heki come in a variety of colors.
HTH,
Steve
HTH,
Steve
americanpanzer
KitMaker: 542 posts
Armorama: 539 posts
Posted: Saturday, August 29, 2015 - 03:28 AM UTC
I've had good results with Woodland Scenics static grass too; good stuff;
spstreeter
KitMaker: 37 posts
Armorama: 32 posts
Posted: Saturday, August 29, 2015 - 03:37 AM UTC
Thanks for the replies. I will look into both of those options.
Biggles2
KitMaker: 7,600 posts
Armorama: 6,110 posts
Posted: Saturday, August 29, 2015 - 07:53 PM UTC
If you haven't looked into static grass applicators yet (you absolutely will need one as static grass will not stand up without one), they are relatively expensive. There are tutorials on line for DIY at about $20, or less, of materials and are pretty simple to make. If you're working in 1/35 you will need the longest possible static grass, about 10 - 12 mm. The shorter stuff only looks good with model railroading.
spstreeter
KitMaker: 37 posts
Armorama: 32 posts
Posted: Saturday, August 29, 2015 - 08:48 PM UTC
Thanks for the tip. Are there other options for realistic grass?
11Bravo_C2
KitMaker: 475 posts
Armorama: 394 posts
Posted: Monday, August 31, 2015 - 07:55 PM UTC
If you do decide to go the diy route, stay away from the electric bug zapper model. Voltage is low and does not stand the static grass very well.
Dannyd
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, August 31, 2015 - 08:03 PM UTC
brekinapez
KitMaker: 2,272 posts
Armorama: 1,860 posts
Posted: Monday, August 31, 2015 - 09:00 PM UTC
What plans did you use for the router psu version?
Dannyd
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, August 31, 2015 - 09:12 PM UTC
My own fella, I read a few that I downloaded but came up with my own, I used a Futaba RC receiver switch soldered onto the the 12V negative ion generator and took the 12v socket from the router PSU. You just have to remember that the white leads from the generator goes to the mesh screen and the negative goes to the earth pin, which gets pushed into the groundwork.
Really simple really, no issues and it works better than some of the expensive ready made versions.
Dan
sdk10159
KitMaker: 556 posts
Armorama: 433 posts
Posted: Monday, August 31, 2015 - 10:03 PM UTC
Check out the grass tufts
http://www.sceneryexpress.com/Grass-Tufts/products/1258/
11Bravo_C2
KitMaker: 475 posts
Armorama: 394 posts
Posted: Tuesday, September 01, 2015 - 01:10 AM UTC
I used this DIY Tutorial from youtube and modified the power input cabling/connector to accept a 12V wall-wart.
brekinapez
Posted: Tuesday, September 01, 2015 - 05:13 AM UTC
Thanks, Dan and Ivan.
Hohenstaufen
KitMaker: 2,192 posts
Armorama: 1,615 posts
Posted: Tuesday, September 01, 2015 - 04:46 PM UTC
You might also like to check out Noch 00412 Grass mat. It is available from model railway shops, mine came from www.ontracks.co.uk in Wales. They do a useful line in scenic materials. The product is a mat of grass that you can tear or cut into whatever size and shape you need. The length is good for 1/35.
avenue
KitMaker: 544 posts
Armorama: 542 posts
Posted: Wednesday, September 02, 2015 - 09:02 AM UTC
can bug zapper you brought on the market do the same job?
erichvon
KitMaker: 1,694 posts
Armorama: 1,584 posts
Posted: Wednesday, September 02, 2015 - 05:39 PM UTC
That looks a superb bit of kit which to be honest I'd never seen before. I'm currently working on a big Normandy dio which will have a decent sized field next to the farm I'm putting on it. THis will be ideal to get the grass looking right rather than that uniform golf course look, especially once tufts go down on it. Definitely going to build one of these. The You Tube videos really easy to follow as well. Thanks for putting them up.
henkp
KitMaker: 1,080 posts
Armorama: 1,064 posts
Posted: Thursday, September 03, 2015 - 05:16 PM UTC
avenue
KitMaker: 544 posts
Armorama: 542 posts
Posted: Wednesday, September 09, 2015 - 12:25 PM UTC
well. I ttempted to construct my own static grass applicator using cheap chinese made electric fly swatter,when unscrew the cover,there are 3 wire,not two.
which one go strainer,and which one go to the diorama base.that left one extra wire,should I cut it off?
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Wednesday, September 09, 2015 - 02:07 PM UTC
Quoted TextThanks for the tip. Are there other options for realistic grass?
SCENERY EXPRESS makes some pretty good products. I like the NOCH Static Applicator. You can't go wrong with WOODLAND SCENICS products, either...
11Bravo_C2
KitMaker: 475 posts
Armorama: 394 posts
Posted: Thursday, September 10, 2015 - 11:41 AM UTC
Picutre? One i made with the fly swatter only had two wire coming off the charge capacitor on the PC board. One cable went to the "hot" middle mesh and the other wire went to the outer neutral/grounded mesh..
