Hosted by Jacques Duquette
VT-55 Recovery Vehicle
joepanzer
KitMaker: 803 posts
Armorama: 740 posts
Posted: Saturday, September 19, 2015 - 06:11 AM UTC
amazing!!
acebatau
KitMaker: 730 posts
Armorama: 616 posts
Posted: Saturday, September 19, 2015 - 08:54 AM UTC
Nice one, looking good!
gastec
KitMaker: 1,042 posts
Armorama: 871 posts
Posted: Saturday, September 19, 2015 - 09:27 AM UTC
Thanks everyone
The rear of the vehicle is starting to look nice and 'busy' now...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Saturday, September 19, 2015 - 10:37 AM UTC
Spade is dry fitted....
Gary
Gary
gastec
Armorama: 871 posts
Posted: Saturday, September 19, 2015 - 01:48 PM UTC
Driver's hatch in place with commander's cupola a WIP...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Sunday, September 20, 2015 - 11:06 PM UTC
Commanders hatch unit now complete...
Gary
Gary
jvazquez
KitMaker: 857 posts
Armorama: 811 posts
Posted: Sunday, September 20, 2015 - 11:29 PM UTC
Another one of those where its going to be sort of sad to see it painted!
Maki
KitMaker: 5,579 posts
Armorama: 2,988 posts
Posted: Sunday, September 20, 2015 - 11:49 PM UTC
Another one of those where its going to be sort of sad to see it painted!![]()
Agreed. It is a very extensive conversion and you're doing a great job on it.
Mario
KoSprueOne
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Monday, September 21, 2015 - 05:50 AM UTC
Well, he took lots of crisp and clear pictures for this model's 'growing up' archives.
gastec
Armorama: 871 posts
Posted: Monday, September 21, 2015 - 01:20 PM UTC
Thanks guys - glad you like it
As nice as this kit is, there are some flaws - one being the simplified cable guide for raising and lowering the rear spade - plus the total absence of any cable and hook. Fortunately, Google provides sufficient reference photos to allow you to bring this assembly up to an acceptable level...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Monday, September 21, 2015 - 02:19 PM UTC
From what I can make out in a couple of images, there appears to be some form of cable guide too on the rear deck so I replicated this using brass rod and some scrap PE...
Will mostly be hidden under the cargo deck when that's fitted though.
Gary
Gary
gastec
Armorama: 871 posts
Posted: Tuesday, September 22, 2015 - 10:56 AM UTC
Kit modified part to form a spotlight for the rear along with added wiring for that and the convoy lights' junction box. Wiring conduit from the hull is lead wire with the end drilled out to give the impression of a hollow tube...
Gary
Gary
Posted: Tuesday, September 22, 2015 - 01:17 PM UTC
Gary
Simply outstanding work! I look so much forward to see it painted, although, as someone already pointed out, almost a shame to cover up all the great conversion and scratch building you've done.
Jacob
Jacob
LKWMAN
KitMaker: 279 posts
Armorama: 279 posts
Posted: Tuesday, September 22, 2015 - 10:50 PM UTC
Hello Gary
A very nice model what you build. But the tail skid was not taken with the auxiliary winch on the vehicle. Given the large winch was used. Bin on your color scheme very interested. My respect for this model.
Best Regards LKWMAN
Best Regards LKWMAN
gastec
Armorama: 871 posts
Posted: Wednesday, September 23, 2015 - 12:48 PM UTC
Thank you Jacob
Joch - I don't have any info on how the spade was raised/lowered, but the aux winch seems plausible. Do you have info to the contrary?
Cargo deck next. I anticipated a few issues here due to slight warpage of parts. The deck floor needed a little heat from a hairdryer to ensure it was flat before added 3 of the sides as per instructions along with locking pins...
The rear 'gate' was a little more challenging so I decided to rebuild it from Evergreen styrene to ensure everything was straight and true - simply replicating the resin parts and using styrene rod instead of the suggested brass...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Wednesday, September 23, 2015 - 02:42 PM UTC
Getting there slowly....
Gary
Gary
LKWMAN
KitMaker: 279 posts
Armorama: 279 posts
Posted: Wednesday, September 23, 2015 - 09:07 PM UTC
Hello Gary
Can anyone help, I think that you still build it to your model different from you.
regards LKWMAN
regards LKWMAN
gastec
Armorama: 871 posts
Posted: Thursday, September 24, 2015 - 01:10 PM UTC
Seems to almost support my theory
Obligatory Soviet saw....
Gary
Gary
mvaiano
KitMaker: 1,054 posts
Armorama: 1,050 posts
Posted: Thursday, September 24, 2015 - 04:50 PM UTC
Hi Gary!
I just see it now.
Great work! I'll follow for sure!
Cheers!
Marco
I just see it now.
Cheers!
Marco
gastec
Armorama: 871 posts
Posted: Saturday, September 26, 2015 - 03:39 AM UTC
Cheers Marco.
The mounting of the cargo bed to the hull was always going to be a challenge for a number of reasons. The support brackets are supplied as multi part PE and while not hard to assemble, contact areas between resin and brass are very small making a strong join difficult. You can't fit the assembly in place prior to painting for obvious reasons and gluing after paint runs the risk of touch ups later showing through. Then there is the conundrum of the aux tow cable being fitted in place due to it running over a couple of guide bars.
After some thought, I decided to remake the support struts from strip styrene onto which is mounted a square frame to act as a base....
The lower base of the bed itself is sanded flat....
... allowing the cargo bed to sit nicely onto the frame....
The bed can now be easily fitted after painting without fear of glue marks etc and the aux winch cable can be threaded as required.
Gary
Gary
gastec
Armorama: 871 posts
Posted: Saturday, September 26, 2015 - 03:41 AM UTC
Just noticed one of the rails on the gate was wonky in the above photos - now fixed
Gary
Gary
gastec
Armorama: 871 posts
Posted: Saturday, September 26, 2015 - 05:20 AM UTC
Draw bar is stowed on the RH fender....
Thought I'd improve upon the resin parts by using brass tube and soldering on new handles to each side....
Gary
Gary
gastec
Armorama: 871 posts
Posted: Saturday, September 26, 2015 - 10:39 AM UTC
Onto the boom next. Here are the main components ready to be assembled...
Base unit assembled....
... and attached to the hull...
Gary
Gary
Maki
Posted: Saturday, September 26, 2015 - 01:12 PM UTC
Very clean work. Gary, this would make an excellent feature for the site. Interested?
Mario
Mario
gastec
Armorama: 871 posts
Posted: Saturday, September 26, 2015 - 10:22 PM UTC
Thank you Mario. Will drop you a PM later...
Boom assembly dry fitted....
Gary
Gary
