RFM is making corrections as it goes along with each release.
Let's look at that. What errors in 5001 have they actually corrected for 5003?
Let's look at physical parts only, and ignore the problems in the instructions (such as the shovel and the starter handle and sighting vane being wrongly specified).
And let's ignore errors that got fixed by becoming irrelevant. The tow cables are now the correct size, but not because they were retooled, they just happen to be right for this later Tiger. The old side mudguards are gone, not corrected.
What have Rye Field actually changed?
The turret smoke launchers
The right-hand mudguard "frame"
An exhaust without a deflector is now provided
The gun length
Now, what physical errors have Rye Field not fixed? Let's ignore the headlight base plates, because you won't see them in this build. Just concentrate on visible errors that were reported publicly.
All the bolts and holes under the turret ring
Top handle on the cupola hatch
The turret seating ring on the hull
Road wheels missing their joint
Please, add to these lists if you know of anything else.
David
