Thank you for that excellent tutorial and results. It looks fantastic!
Gary
M4A3 Sherman 105mm Howitzer
Posted: Saturday, December 05, 2015 - 07:26 AM UTC
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Monday, December 07, 2015 - 05:48 PM UTC
Thank you very much for all your comments, still a bit of experimenting, but the real deal comes when you start doing the green color. You have to switch your mind to paint like you were using water colors looking for transparent results, so the previous work can be shown between the layers. Yes you eventually will need to retouch some of the work, but you have the advantage that you can see where exactly. In my case was minimal .
I just sealed again the work for the decals process, meanwhile I can start painting the tools and all the small parts that were left out of the big painting process.
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Tuesday, December 08, 2015 - 04:52 PM UTC
And here is with the markings done using template from Lion Roar WWII US Vehicles Markings 1. First time using it and I must say I love the results.
acebatau
KitMaker: 730 posts
Armorama: 616 posts
Posted: Thursday, December 10, 2015 - 04:02 PM UTC
Looking good, love it and thanks for great tutorial
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Thursday, December 10, 2015 - 04:47 PM UTC
GREAT WORK! This is a different technique that shows what really can be done with judicious use of airbrushing skill!
I myself haven't used the White paint technique, although on my next project, I think I'll give it a go. My usual technique:
I prime, paint a dark OD base, and then progressively lighten my OD with additions of Panzer Yellow, shooting in "cloud patterns". Once these coats have dried, I then "shade" with my own mixes of weathering powders in certain areas. A coat of Clear Sem-Gloss to seal everything, then I like to apply my markings- either decals, dry transfers, or airbrushed-on, using stencils, depending on what I want to depict. Once markings have been applied and have dried, I like to apply a dark pin-wash in the appropriate spots, then I shoot the whole thing with Clear Flat. I prefer TESTORS 1960 Lusterless Flat, in the spray can. It dries dead flat.
I like to use a regular graphite pencil to simulate wear around places that have had a bit of paint-wear: Sprocket-teeth, Hand grabs, etc. I don't use much "Rust" at all; Exhaust Pipes and chains get a bit of it. I usually depict my US/Allied stuff with very light weathering- a light bit of road dirt and/or mud, a very light dust coat, and a tiny bit of dry-brushing on raised details... My tracks get my usual look to match my road dirt/dust...
I'd like to say that this build shows very graphically what can be done with an older kit to make it a WINNER!!! VERY NICE WORK, indeed!!!
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Thursday, December 10, 2015 - 06:39 PM UTC
Quoted TextLooking good, love it and thanks for great tutorial
I'd like to say that this build shows very graphically what can be done with an older kit to make it a WINNER!!! VERY NICE WORK, indeed!!!![]()
Hi! thank you for all your kind words! Its really great to share what I learn along the way with others.
This is my third attempt using this technique, you can check on the other 2 and see for yourself the progress between them:
https://armorama.kitmaker.net/forums/238248#2009615
https://armorama.kitmaker.net/forums/231915#1954751
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Monday, January 04, 2016 - 08:05 PM UTC
Some progress on the Sherman, started the Fading process using oils.
I used some blue oils for the shadows and some yellows for the highlights. I Blend the yellows and the blues separated from each other and here you can see the results.
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Wednesday, January 06, 2016 - 06:06 PM UTC
Well this fella has come to the finish line, Dust and mud added, figure done, lens lights added using Sticko silver dots, stowage is handmade using Aves Epoxy, just need to add a rope and some loose tools. Hope you like it, its a great kit considering the old it is.
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Wednesday, January 06, 2016 - 06:08 PM UTC
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Wednesday, January 06, 2016 - 06:53 PM UTC
So on this final animation you can see thw whole process in seconds to the final stage. Hope you like it and can help you work on yours!
robw_uk
KitMaker: 1,224 posts
Armorama: 1,207 posts
Posted: Wednesday, January 06, 2016 - 07:02 PM UTC
mus say thats rather nice.. hope my M5A1 and M4E8 look half as good when I am done with them....
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Wednesday, January 06, 2016 - 09:44 PM UTC
Fantastic result Pedro. The final result has convinced me to try some pre-weathering as you have demonstrated. Not sure I have the patience with the black/white technique but I already have an idea for a variation that will require less work on my part. Very inspirational to this old modeler.
Chapman
KitMaker: 203 posts
Armorama: 198 posts
Posted: Thursday, January 07, 2016 - 01:41 AM UTC
Pedro,
Love the subtle tonal finish you achieved while still achieving a lot of chromatic variation throughout the whole vehicle. Great way to present it also with the animated gifs.
bat-213
KitMaker: 902 posts
Armorama: 788 posts
Posted: Thursday, January 07, 2016 - 03:48 AM UTC
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Thursday, January 07, 2016 - 08:03 PM UTC
love the way you did the paint.looks very dirty.very well done.
@Robert: Hope my work give you inspiration, but most important, have fun with the kit!
@Dvsand: You can skip the black & white and make a color modulation of your choice using the base color and add the proper color for highlight and shadows then you can follow with the next steps, have fun!
@Chris: Thank you very much! the animation help a lot to keep you in perspective the lot of steps in order to achieve the final result, I just love to do it this way!
@Roy: Thank you very much! Can be done with much less dust and mud accumulation and still look great, is just choice and a very good reference picture to keep focus on that idea.
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Thursday, April 14, 2016 - 11:24 PM UTC
You can see more examples in a well explained way in the book of Jose Luis Lopez Black & White Technique Book from AMMO.
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Wednesday, August 10, 2016 - 04:55 PM UTC
A recent picture of the kit in a exhibition
Fletcher445
KitMaker: 11 posts
Armorama: 11 posts
Posted: Wednesday, August 10, 2016 - 05:05 PM UTC
Very nice work. I am building the same kit straight out of the box for no other reason to practice some new weathering techniques. Now I need another one to try the black and white modulation. Your end result came out quite spectacular, so I want to try it some time.
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Tuesday, November 08, 2016 - 07:15 PM UTC
Hi fellas, I wanted to share this recent pictures of the Sherman from a Scale Model show that took place in my country.
robw_uk
Posted: Sunday, July 23, 2017 - 01:51 AM UTC
Argh, was going to use this as inspiration for my Eduard M4A1 build.... Where can I see your photos????
catdude01
KitMaker: 314 posts
Armorama: 253 posts
Posted: Friday, August 30, 2019 - 01:31 PM UTC
Look again, the pictures are back online.
