I got 2 detail sets for this. The Eduard PE set and a Legend detail set, no. LF1189. Both are nice, and they compliment each other quite well. Unfortunately, by the time I got the Legend set, I already had a lot done on the model, so I ended up having to remove some things to put the resin parts on.
The tail lights units ended up being a mix of parts from both sets. The light guards on the Legend set had fold lines etched in, but they ended up looking to boxy and angular. The Eduard parts were marked for bending a more curved corner, and they had surface detail etched into them. The Eduard inner brackets were nicely detailed, but very complicated to fold into the correct shape; too difficult for me. The Legend parts were easier to fold up right and install. I then added the detailed face from the Eduard brackets to the Legend parts (confused yet?). The Legend set has some very nice resin tail lights, the Eduard set just has you use the kit lights (how are you supposed to remove them from the rest of the part?).
On the front lights, there really is no choice, as Eduard does not supply them. So I had to use the Legend set. The resin parts are great, the PE guards not so much. Unlike the tail lights, there are no marks, lines or guides to show you where to make the bends in these pieces. It is simply a matter of guesswork and trial and error. A lot of error. I was not able to get them exactly right, but they are as close as I can get them; and they do look pretty good.
