Received the sprue “J” from RFM today. Thanks RFM and Jim for getting that to me so fast.
And the build continues……
First, I want to apologize for giving out wrong information. I was asked if the road wheel arms were movable in this kit and I answered yes. The way the kit is built, the road wheel arms are not meant to move. Torsion bars are included, but the arms have locking pins. It is possible to have the road wheel arms move by removing the locking pin.
Next is more evidence that there could be a full interior, including engine, coming from RFM soon.
This picture shows a location point where the batteries would go. The only thing is that on the hull, the doors to access the batteries are molded to the hull. Maybe a new hull will be included?
Possible engine locating spots:
And drivers compartment:
Did work on the loaders hatch, external APU, and TC’s station…
There was a major problem with the TC hatch…
The engine doors and grills look very good. They were a bit tricky to put together but if you attach the hinge parts first, then attach the doors, it goes to better easier. The tail lights are not that bad looking either.
Road wheel arms, torsion bars, return wheels and all the other nick nacks that go behind the tracks went on with now problem. Even with the locking pins, there is still a little play with the road wheel arms, so use a straight edge or something level to level out the arms while they dry.
Now was the time to mate the upper with the lower hull. The front of the hull was a good tight fit. Under the left and right rear has some small gaps. If it bothers you, you can fill these gaps, but for me, since you won’t see them, I won’t bother filling them.
There is 3 places on the hull that will need to be filled and sanded and fixed. First is the front glacis plate. The front did have the weld seem molded on the bottom hull, but it was faint. So I sanded it all down and will use some Evergreen rod to replace the weld bead.
Next spot that will need filler and sanding is the right rear side of the hull…
Last to show in this update is the left rear area of the hull. Since I am building the M1A1 with Tusk version, I used the fuel cell panel that goes glued atop the right rear. The u shape and lip seen on A2’s with the APU and or Hawker Batteries is not visible on the A1 that I am building, so fill and sand this area. The other area is where the upper hull meets the rear. This needs to be filled and sanded.
Well, that’s it for tonight’s update.
