Here is the Commanders Cupola.
Up Detailing the M48A3 from Dragon
OldWarloke
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Thursday, July 14, 2016 - 08:21 PM UTC
I have some more done .
OldWarloke
Posted: Thursday, July 14, 2016 - 08:25 PM UTC
Now to install the Gun.
You will need a piece of tubing that fits over the end.
OldWarloke
Posted: Thursday, July 14, 2016 - 08:30 PM UTC
Now the Tow Cables.
That's all for now.
Donald
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Thursday, July 14, 2016 - 09:47 PM UTC
Some really nice looking work. Project is coming together quiet well. The AM goodies really to the build. Anxious to see some paint on the beast.
OldWarloke
Posted: Friday, July 15, 2016 - 06:15 PM UTC
Base Coat painted.
Now it's time for the detail painting, then on to assembling the Track.
Donald
Donald
exgrunt
KitMaker: 301 posts
Armorama: 301 posts
Posted: Friday, July 15, 2016 - 06:32 PM UTC
You're doing some great work. This has been very informative. Keep posting!
JSSVIII
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Friday, July 15, 2016 - 07:31 PM UTC
What color/brand did you use for the base Donald?
OldWarloke
Posted: Saturday, July 16, 2016 - 07:24 PM UTC
The instructions call for Model Master #1711 FS34087.
I used Model Master #1787 FS34086 Green Drab
I think that the FS34086 looks a lot closer to what I saw in Vietnam many years ago.
Donald
OldWarloke
Posted: Tuesday, July 19, 2016 - 08:27 PM UTC
Here is the Track I'm planning on using .
The Parts.
A lot of clean up here.
I started off with the Connectors and Guide Horns .
First off this is how I did it, there are other ways to do it.
This way I found it is less likely to get the glue into the working parts when adding the Guide horns.
The Parts.
OldWarloke
Posted: Tuesday, July 19, 2016 - 08:35 PM UTC
I'll be pre painting the Track Pads be fore assembling them.
Donald
BruceJ8365
KitMaker: 441 posts
Armorama: 441 posts
Posted: Wednesday, July 20, 2016 - 07:50 AM UTC
Holly crap! Those tracks would drive me nuts after the 100th time a piece stuck to my fat fingers!
I don't think there's enough ritilan in the world to keep me focused that long.
Amazing work... I feel like an armchair modeler - when I get to a frustrating part or get bored with the repetitive tasks, I set it aside, and go buy another model to stash away.
OldWarloke
Posted: Thursday, July 21, 2016 - 12:30 AM UTC
I have the Track parts painted.
I painted the Track Pads Nato Black.
I then masked off the Black to paint the inside metal areas.
Here is what they look like after painting.
The connectors after painting.
Now I have a lot of trimming to remove the parts from the Sprue, then the touch up painting on the black areas.
Regards.
Donald
Regards.
Donald
OldWarloke
Posted: Saturday, July 23, 2016 - 07:14 PM UTC
I have all the parts cleaned up and painted, all 1,140 of them.
Now to start the assembly.
Donald
Donald
OldWarloke
Posted: Sunday, July 24, 2016 - 10:33 PM UTC
I figure I had better get the wheels installed, so I have something to wrap the track around to get its final length.
The tubing was glued to the axles, and the wheels are just press fit.
They stay on realy good. This way if I screw this up, I can salvage the wheels.
OldWarloke
Posted: Sunday, July 24, 2016 - 10:40 PM UTC
I started the track.
The Brass areas are 1/4" square tubing that I made into a jig for track assembly.
OldWarloke
Posted: Sunday, July 24, 2016 - 10:44 PM UTC
OldWarloke
Posted: Sunday, July 24, 2016 - 10:48 PM UTC
I'll have more Pics. when I get the track finished and installed.
Donald
jekrott
KitMaker: 485 posts
Armorama: 353 posts
Posted: Sunday, July 24, 2016 - 11:44 PM UTC
Coming along nice,must be a labor of love with all those pieces.
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Sunday, July 24, 2016 - 11:45 PM UTC
That is a ton of track parts!! Looking real nice
Armorsmith
Posted: Monday, July 25, 2016 - 12:44 AM UTC
Lots of work but by the looks of them they seem to be worth the effort.
OldWarloke
Posted: Monday, July 25, 2016 - 09:59 PM UTC
I finally finished and installed them.
First here are a couple of Pics. showing a comparison of the Bronco Track and the Dragon kit Track.
Both inside and outside .
The Dragon Track has 76 shoes and it took 79 of the Bronco Track shoes to make the track run. The Dragon Trac was just the right length.
The Dragon track pads are slightly larger than the Bronco ones.
I don't know which if any of them are correct.
OldWarloke
Posted: Monday, July 25, 2016 - 10:06 PM UTC
It was tight getting the Bronco Track to fit, I used 79 links, 80 would have been way to loose.
The track is rather tight, not really that workable .
I first fastened the correct end of the track to the top of the sprocket, then bent the track around the wheels ending back at the sprocket. I had to stretch it a little to get the track end connectors to line up with the sprocket teeth.
Here is how it looks around the sprocket.
OldWarloke
Posted: Monday, July 25, 2016 - 10:15 PM UTC
Well that's how I did the track, I'm not shure if I ever want to do that again, way too much work.
Donald
OldWarloke
Posted: Thursday, July 28, 2016 - 12:29 AM UTC
I'm all finished with this one.
OldWarloke
Posted: Thursday, July 28, 2016 - 12:33 AM UTC
