One thing that is wrong in the box art is suspension - it shows the A2 version geometry (the upper run of track goes upward from 4th road wheel to the idler, over the fifth wheel). I hope the kit will have correct M113/M113A1 suspension (track should rest on the fifth wheel and go practically horizontally to the idler).
The A2 had increased ground clearance and idler was mounted higher, what introduced about 3 inch difference between the level of road wheel top and idler wheel top. In M113/M113A1 the tops of idler and road wheels were at almost the same level.
We need to see the plastic. Hopefully it is just the box art artist mistake.
Ok, so Pawel, please bear with me, and help me out here mate if you can. From the information I have (M113/A1 and A2 FOV), there are two types of idler spindle and two types of arm. Now both spindles are mounted in the exact same rosan inserts in the hull. However, with the A2 version, the plate that extends out from the rear of the hull for the other four bolts differs on the A2 version. The arm for the idler (A2) seems to be 180 degrees in the other direction as compared with the M113/A1? Hence the higher idler on A2's etc. Can you confirm this?
Cheers Jason
