Tamiya M10 Wolverine Build
British Columbia, Canada
KitMaker: 72 posts
Armorama: 70 posts
Posted: Sunday, September 18, 2016 - 08:55 AM UTC
Nice painting Colin!
@Gord: Please read my explanation about the hex nut bosses on the hull tub floors. This isn't a concession to toylike features. Those bosses are hidden and will be unused by 98% of modelers.
Thanks Roy.
Consider it read. You, as usual are the man.
Still, if you wanted to detail the driver area it would be a bugger to scrape off. It's kind of a weird choice by Tamiya don't you think?
Gord
KitMaker: 72 posts
Armorama: 70 posts
Posted: Monday, September 19, 2016 - 12:31 AM UTC
Starting on preliminary weathering now. I have had some requests to detail how I do my weathering so I will attempt a bit of an SBS here.
This is a great effect, I can really see the metal aging before my eyes. Well done and thanks for showing how.
Gord
Michigan, United States
KitMaker: 4,021 posts
Armorama: 3,947 posts
Posted: Monday, September 19, 2016 - 12:40 AM UTC
Gord
I'm looking at mine right now. I believe Tamiya placed the fwd hex boss right where the transmission housing would rest on the tub floor if they were to repurpose the hull and use it in a variant where they'd include a driver's compartment.
But if not, it's still not a big hurdle for the modeler who wishes to drop in their own. This kit's lower hull isn't the tub we've often seen. It's several flat slabs. Thus, to remove the hex boss, all one would need is a razor saw.
Roy Chow
Join AMPS!
www.amps-armor.org
Australian Capital Territory, Australia
KitMaker: 21 posts
Armorama: 21 posts
Posted: Monday, September 19, 2016 - 12:27 PM UTC
I have also been lurking around and following this build closely Colin. It is a beautiful build so far. I have really been enjoying your SBS build and captions with comments outlining different steps, especially the weathering technique! Have learnt a lot of useful weathering techniques and it would be great to keep doing the same. Thank you
KitMaker: 72 posts
Armorama: 70 posts
Posted: Wednesday, September 21, 2016 - 06:16 AM UTC
Of course you are right, I hadn't thought of that, Too used to big hull tubs from Tamiya.
With all the nice work in the fighting compartment I am still a little surprised that Tamiya totally cheaped out on the drivers compartment.
Gord
KitMaker: 1,607 posts
Armorama: 1,581 posts
Posted: Sunday, September 25, 2016 - 01:57 AM UTC
ColinEdm
Associate EditorAlberta, Canada
KitMaker: 1,355 posts
Armorama: 1,229 posts
Posted: Sunday, September 25, 2016 - 03:44 AM UTC
The voices are back.....excellent....
KitMaker: 142 posts
Armorama: 137 posts
Posted: Sunday, September 25, 2016 - 06:29 AM UTC
Excellent weathering work Colin! Thanks for the reply about pre-shading.
John
New Mexico, United States
KitMaker: 681 posts
Armorama: 603 posts
Posted: Sunday, September 25, 2016 - 08:15 AM UTC
Nice progress Colin! It's going to look really nice when you are finished.
On the Bench
MiniArt Grant Mk I with Interior
IBG Marmon-Herrington MKII
KitMaker: 803 posts
Armorama: 793 posts
Posted: Sunday, September 25, 2016 - 04:53 PM UTC
That's coming along really well Colin,
I have the kit in the stash so I've been following your build and I'm impressed
Regards
Dan
Putrajaya, Malaysia
KitMaker: 2,511 posts
Armorama: 913 posts
Posted: Sunday, September 25, 2016 - 09:21 PM UTC
Nice work ... i never had succesd with oil filter.. love the effect that u did.... perhaps i can share how i did it...
Sil
The more i know, the less I understand!!!!
tatbaqui
News Writer
#040
Metro Manila, Philippines
KitMaker: 2,713 posts
Armorama: 2,451 posts
Posted: Monday, September 26, 2016 - 06:58 AM UTC
I like how your weathering is coming along Colin -- have picked up on what oil colors to use for such a base coat.
The tracks are single piece, vinyl-like flexible plastic that can be joined with regular model glue (I used Tamiya Extra-Thin). Detail is good and they fit snugly.
Just curious on how you mounted the kit-supplied tracks -- any special care / technique you had to do? I ask as I just read one's ongoing M10 build that had his track torn, thus needed to be stapled.
ColinEdm
Posted: Monday, September 26, 2016 - 07:59 AM UTC
Thanks everyone! Hopefully I can keep it up for the est of the weathering.
Tat, I saw the torn tracks in the Tank Hunters campaign as well. I clamped mine after gluing to make sure the join was nice and strong as they did have a tendency to want to pull apart. Nothing special for putting them on really.
KitMaker: 3,736 posts
Armorama: 3,697 posts
Posted: Tuesday, September 27, 2016 - 03:11 AM UTC
Since 1997, Tamiya has used a styrene-vinyl blend for their tracks, which is a mixed blessing. It can be glued with normal cement, but the new plastic is more fragile than the original vinyl (which was nearly indestructible). I have had Tamiya tracks snap where they had been folded to fit in the box, for instance. This Tamiya flexible plastic blend must be painted with acrylic paints only--enamel or lacquer paints or thinners will attack the soft plastic, causing it to dry out and crumble, sometimes within days.
tatbaqui
News Writer
#040
Posted: Tuesday, September 27, 2016 - 04:02 AM UTC
Thanks Colin! I have the M10 lined up for a campaign so its good to know what's ahead in building this kit.
Gerald, Tamiya re-issues kits like its Pz II F/G. I've bought a couple recently, and judging from the looks of the packaging it clearly is not of either 70's or 80's vintage. Is it safe to assume that that its tracks would be those of the styrene-blend. If so, is there a way to confirm?
Posted: Tuesday, September 27, 2016 - 05:56 AM UTC
I have not revisited the older kits since the change (there are usually newer kits from other makers), but you could try adding a few drops of cement to the runner (sprue) the tracks come on. If it becomes tacky where the cement touches, it's the new stuff. If the plastic is unaffected, it is vinyl. Of course, another clue would be the instructions--do they suggest gluing the track ends together, or welding them with a heated knife blade? [Actually my favorite classic Tamiya instruction said to drive a small tack into the end of a wooden chopstick, and heat that to make the weld]
tatbaqui
News Writer
#040
Posted: Wednesday, September 28, 2016 - 07:19 PM UTC
Will give it a try. Thanks Gerald! Tat
KitMaker: 185 posts
Armorama: 130 posts
Posted: Friday, September 30, 2016 - 12:28 AM UTC
I like it very much, lets hope they get an M-18 out
ColinEdm
Posted: Saturday, October 01, 2016 - 12:15 AM UTC
ColinEdm
Posted: Sunday, October 02, 2016 - 08:27 AM UTC
Continuing on, painted up the exhaust, basically just layering up different rust shades with a bit of rust pigment mixed in to get the corroded texture. Will top off with some more pigments at the end.
A light oil drybrushing to bring out some details
And on to the pin wash, I like oils for this because of the long working time. I mixed up a black/raw umber mix and apply sparingly with a fine brush.
Let it dry and then with a soft brush just barely dampened with turpenoid I gently brush away the excess. Make sure the brush is almost dry or you just wash away everything. You just want to leave a nice shadow behind.
KitMaker: 681 posts
Armorama: 603 posts
Posted: Sunday, October 02, 2016 - 08:39 AM UTC
On the Bench
ColinEdm
Posted: Sunday, October 09, 2016 - 03:43 AM UTC
Finished off the pin wash, followed with a bit more drybrushing:
Time for chipping, set up my wet pallete and got the brush and foam shreds ready:
After chipping:
Also painted up the tracks, dark grey basecoat and added several washes (rust, earth) for the metal parts.
Will do an overall wash and then follow up with pigments.
tatbaqui
News Writer
#040
Posted: Sunday, October 09, 2016 - 04:20 AM UTC
Looking good Colin. I especially like the way you have done the modulation for such a single color finish.
ColinEdm
Posted: Sunday, October 09, 2016 - 04:29 AM UTC
Thanks Tat! I have really gotten into this technique, I really like how it gives a single colour paint scheme more life.
ColinEdm
Posted: Thursday, December 15, 2016 - 09:43 PM UTC
