Time to get started on the Zvezda Gaz-AAA and Miniart Field Kitchen. To be honest, I started on the Gaz-AAA first but hopped over to the Field Kitchen. And while I'm being honest I'm going to skip through these builds a bit....especially the field kitchen kit. I got ahead of myself and didn't take alot of photos.
The Field Kitchen goes together okay. There's a good bit of cleanup involved but it all tends to fit. I've built the Tamiya German Field Kitchen and wish Miniart had included a separate pot so it could be more easily posed "in-use". Likewise, I would have liked to have seen the firebox engineered to be modeled with the door open so you could pose it in-use. For this project, the rig will be hitched to the Gaz-AAA in transport mode so it's not a huge deal.
There's not a lot to the kit. Most of the parts are fittings. The wheels are sandwiched/layered circles to give it that treaded look. The cooker is minimal...I guess you could rework it and give the pot and firebox. The box is six sided with a pull-out tray to use as a table.
The kit comes with a cook figure and Miniart's Soviet Inf at Rest set. I won't use the infantry set...I might use the cook. It comes with two food holder things. I would have liked to have seen some more accessorie likes food crates, flour sacks, mess kits, water cans, etc. ...mainly food supplies to put in the back of the Gaz
Anyway, assembly is done and it's waiting on the Gaz-AAA to be assembled...I'll paint both at the same time.
Speaking of the Gaz-AAA...the Zvezda Gaz-AAA is obviously an older kit. It's actually an old Toko kit that has also seen life as an Eastern Express kit. It's pretty basic. I'll probably replace it at some point with the Miniart Gaz. It comes with a canas top. Depending on if I can scrounge up some cargo, I'll probably scratch up some support rods and "stow" the canvas top.
I assembled the engine. The engine isn't that bad. The frame is one-piece except for the rear crossmember. The bed is supported by a pair of wooden beams that sit atop the frame.
The truck's bed is basic. The bed panels' fit are rough. The cab body fits badly on the frame. The engine fits even worse. The instruction get iffy with the exact placement of the bench seat base...which I assume also served as the fuel tank. There's no fuel cap...which I will probably add since I probably will have at least one door open. Firewall, steering column, and steering wheel are added.
More to come.
EDIT: Re-hosted pictures
