Powder bags , how many kept out?
KitMaker: 1,388 posts
Armorama: 1,357 posts
Posted: Tuesday, April 18, 2017 - 01:40 AM UTC
in Vietnam, the max charge was always the goto charge. never exactly knew why, and I spent an agonizing six weeks in the FDC section. On a typical towed 155 unit you shot four white bag charges for every single green bag charge. I've shot white at 3000 yards and out to 14,000 yards. Yet I've shot green bag from 100 feet to 3000 yards.
As a former Fire Direction Officer (FDO) who ran an FDC in Germany for a year I can answer that question. There are two reasons you want to use the HIGHEST charge possible when calculating firing data.
For any given range to the target there are usually two or more possible charges (or number of powder bag increments) which will reach the target so you CAN select any of them.
However the more increments you use, the higher the muzzle velocity of the round when you fire it and while it would seem that the answer is that it gets the round there FASTER, and that's true, the difference is not more than a few seconds.
The primary reason for using a higher charge is that because of the faster muzzle velocity, the round will not drop as far during the (shorter) time it takes to get there, meaning instead of having to point the muzzle higher in the air, you can shoot with a flatter trajectory. The faster and lower trajectory makes it MARGINALLY more difficult for a counter fire radar to detect your position, although I'm certain that the technology of today makes even that less of an issue.
A flatter trajectory is also better if you have to use a MECHANICAL time fuze and you're looking to get a 50 meter height of burst. If the round is coming at the target in more of a "down" angle as opposed to an "across" angle, a very small difference in the time setting can make a big difference in the height of burst. Variable or Proximity fuzes don't have that problem.
And the OTHER reason for using a higher charge is simply fewer left over bags which are hanging around in the pit and have to be laid out and burned.
great post Sir! I never knew why, and the only thing I ever could come up with was an easier bore calculation for tube life. We usually went for a 20 meter height of burst, but have heard that burst rate was all over the place. I've even seen three howitzers shoot a time fuse while the other three shot PD on a rare occasion.
One issue not pointed out here is the recoil verses displacement. With the barrel close to being in a level position (or negative); don't even think about using white bag powder! I've seen a couple guns jump the parapet. This gets ugly fast! So this is why you opt for a low green bag charge there. One of the worst experiences I had was a blown recoil cylinder in the early hours right before dawn. We were shooting HE with a charge seven on H&I's. The gunner should have caught the blown cylinder, but instead opted for the ride. The recoil was so harsh that it blew out a series of 16x16 oak logs and went another four feet past them. Good thing was it was H&I's, and there were only three guys near the carriage. The AG and I were pretty bruised up, but still OK. Gunner had to change his shorts.
gary
Posted: Tuesday, April 18, 2017 - 01:41 AM UTC
anybody see what's wrong with the AG and the powder on the same side of the tube?
gary
Posted: Tuesday, April 18, 2017 - 01:50 AM UTC
As a former Fire Direction Officer (FDO) who ran an FDC in Germany for a year I can answer that question. There are two reasons you want to use the HIGHEST charge possible when calculating firing data . . .
Was there any consideration for the faster barrel wear (from using higher charges) when choosing the firing data?
KL
Kurt, I don't remember all the factor numbers, but on a 155 the charge seven was called out as a one towards bore life. Think the charge six was either a .6 or a .7. There was a 10,000 wear number that these were subtracted from. There was also a bore scoping process that came in at maybe 5,000 rounds (could be 2K). I've seen barrels changed at 5,000 many times, and even a couple changed after 2500 rounds with a breech failure (they opt to do both if they see something they don't like). We were supposed to keep track of what we shot, but rarely did. The Chief of Smoke always did anyway.
gary
Michigan, United States
KitMaker: 1,610 posts
Armorama: 684 posts
Posted: Tuesday, April 18, 2017 - 03:46 AM UTC
gary
Brain fart! You're right of course, it should have been a 20 meter HOB, good catch.
While as mentioned, we did keep track of rounds and charges fired and checked for wear to make sure that we didn't lose too much muzzle velocity, I don't recall ever really being directed to stay away from higher charges for that reason. But depending on where and when you were, that certainly could have been part of the decision.
Posted: Tuesday, April 18, 2017 - 11:17 AM UTC
gary
even more off topic, but still relevant to powder and powder charges is the fun game of shooting direct fire and trading rounds with the other guys. A howitzer, or gun, or rifle doesn't have sights. Yes it's got the one for indirect fire and aiming stakes. It's something you keep notes on and also the yardages your shooting at. Sometimes your better off just jumping up a charge rather than moving the barrel up or down. Plus nobody ever made a cross hairs for shooting direct fire. We always pre-registered a lot of short yardage targets during the afternoon. That way you can actually see what your doing. When you find a good combination, you make note of everything. Even then you'll only be close the next time.
If your playing in the hundred yard arena, you don't have time to look thru the barrel to find the target. You sorta guess, and hope your right. You drop the barrel as low as it will go, and tell the kid with the spanner wrench to give you less than two seconds on a couple WP rounds. You tell everybody but the AG and loader to get outta the place as they're not needed. No rammer staff is used as it won't make a difference this time. I've done one second several times, and the round explodes right out front of you.
Got too far off the topic! Barrel life is strange. I've came back to an empty base camp to refit and lick my wounds. The guns get beat up pretty good, and we usually go over them pretty good. If the breech is sticky after cleaning and polishing; we send the gun back for repair. If they change the breech they usually change the barrel as well. Recoil cylinders catch a real beating, and you can't have a failure out by Laos. So we usually have all them replaced one gun at a time. Takes three to four hours to replace all this stuff. So in a week we're ready to move again. Worst part of all this is cleaning the bore prior to firing the first round (the only time it's ever cleaned).
gary
ever shoot those plastic tipped fuses that sent out the radio beam? I remember plotting them in FDC, and of course I've shot them.
Rhone, France
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Tuesday, April 18, 2017 - 12:06 PM UTC
Just came across another view of a 175 mm gun propelling charge :
H.P.
Armorama: 684 posts
Posted: Tuesday, April 18, 2017 - 07:10 PM UTC
Yeah, those are VT (Variable Time) or "proximity" fuzes. As you said they send out a signal which when a strong enough return is received due to the designed proximity of the fuze to an object, causes the fuze to set of the round. You can set an actual time value and it will go off at that point even if it's not that close to the ground, but of course the object is to get a precise HOB above the ground so you can get the proper effect on the target, usually troops in the open with little or no overhead cover.
In the 70's we still had a LOT of the old Mechanical Time fuzes and as they were cheaper, we mostly use them, but we always had some VT fuzes around.
Those things were developed in WWII, primarily for anti-aircraft usage. Trying to get shells to detonate at the same height as an airplane was pretty damn hard in the early 40's as first you'd have to "guess" how high the planes were, and then try to get the shells to go off at that altitude.
The ability to miniaturize a radio transmitter and receiver which would fit into a fuze AND withstand the forces on firing the projectile was a significant accomplishment. It was such a secret that initially the US only allowed the NAVY to use them with the idea that if the shell somehow never went off, there would be no chance of the enemy recovering the fuze intact as it would go into the ocean. Eventually it was finally authorized for ground units in Europe to great effect.
Posted: Wednesday, April 19, 2017 - 02:15 AM UTC
we used 565's mostly, but also had 563's (I think that's the #). The radio beam fuse was pretty expensive in 68 ($120), so we didn't shoot them all the time. The timer dial was used to clear the round from all the high points it passed over. Sometimes impossible in the mountains. Another issue with that fuse is that you can't punch it out if the fire mission is suspended. Very dangerous to do.
gary
Oregon, United States
KitMaker: 525 posts
Armorama: 266 posts
Posted: Wednesday, April 19, 2017 - 02:40 AM UTC
So---you sit back and relax with a live round with an armed radio proximity fuse in the tube?
These are great days we're living, bros. We are jolly green giants, walking the Earth with guns.
-C. Earl
KitMaker: 2,402 posts
Armorama: 2,377 posts
Posted: Wednesday, April 19, 2017 - 04:00 AM UTC
They are bore-safe, meaning they can't initiate until fired, plus the VT fuze isn't "armed".
For mechanical fuzes (US spelling) they need to see some combination of g-force and rotation to get the various internal parts to line up such that the primer can fire. VT fuzes use batteries that need g-forces and rotation to release the electrolyte and mix it with the electrodes. Otherwise, there's no power in the fuze.
The main problem with ramming out a VT fuze is the fragility of the fuze and, if I recall, the shape, which is not a good fit with the ramming cup.
KL
KitMaker: 1,792 posts
Armorama: 1,186 posts
Posted: Wednesday, April 19, 2017 - 07:21 AM UTC
KL
So like a 40mm grenade it's got to be fired and start spinning to arm it. Tho unloading a grenade launcher is probably a bit easier than a cannon.
Posted: Wednesday, April 19, 2017 - 09:06 AM UTC
KL
a fuse is armed by the G forces generated during rotation, but they will still explode. The 565 fuse metal. You just don't want to punch the VT fuse out of the barrel. The end bell will clear the fuse, but it only takes one slight screw up.
The easy way out is to simply shoot it into a safe place. The other issue is how hot the tube is, and really what time of day it is. At night, you just shoot an H&I target. If it's in the morning or early afternoon you call in a FAC to find you a target.
Heat is the real issue, as it tells you how much time you have. As for a fuse being safe unless it's fired; I can vouch that a fused up round will explode from heat alone.
gary
Posted: Wednesday, April 19, 2017 - 09:24 AM UTC
KL
that's what they'll tell you, but don't believe it! I had a powder bunker catch two 122 rockets out at A102. We were trading rounds, and guess we made them mad when they shot salvos of 122's. The powder in the tubes went flying around like fireworks. At least one tube landed in one of the fused round stacks (about a 150 rounds). Several HE rounds went off, and the explosion flung rounds over a hundred fifty yard radius. They had to blow every round in place, and they spent close to a week blowing up rounds. Good thing was that half the guns were out on an OP, so we had to move one gun. Ours was a combat loss. Couldn't have shot it anyway with three kids left.
gary
Posted: Wednesday, April 19, 2017 - 10:51 AM UTC
That's not a case of the fuze "functioning" though. There is a complete explosive train in there, down to the sensitive primary explosive in the initiator. If it gets hot enough it will explode. Much like a propane cylinder is safe - unless you put it in a large fire.
Some modern fuzes are designed so that it is not just the mechanism that is held out of line until fired, the primer/initiator is as well. So, even if the most sensitive part of the explosive train explodes because of a unplanned event, the train will not progress.
KL
Posted: Thursday, April 20, 2017 - 02:45 AM UTC
KL
been more than one hand blown off from tampering with the outside cove on a fuse. A PD fuse contains a greater explosive amount than a typical timed fuse. That's why you leave the supplemental charge in place, while removing it with a PD. A damaged fuse is never used, and returned to EOD for disposal.
gary
Oklahoma, United States
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Friday, April 21, 2017 - 04:58 AM UTC
Man glad I asked keep it up.
If not so old got me wanting to join the Artillery.
Jeff
Posted: Friday, April 21, 2017 - 11:28 AM UTC
Jeff
some of it was fun and some of it not so fun. Arty units tend to shoot all night and work on the gun all day. Three or four hours sleep is the norm. Depended on your location and your position in the battalion. We were the unit that sorta reached out, while another unit was called the jump battery. Those guys were tough, and never spent two weeks in the same place. But they stayed in a 30 klick radius. We went all the way to Laos and south to the II-Corp border. North depended on who called for you.
Some of the best drunks I've ever been on were over there, and some of the worst times was there. Unlike most fools, I got to do Tet twice. Plus who knows how many offensives. They all run together after awhile. I lost my crew three times while I didn't get a scratch. Had my gun CBL'd twice, and it was destroyed a third time right after I cleared out. Guess we were hard on equipment. I've re-conned so many hills and mountain tops that all seem to run together. I honestly don't remember half of them anymore. Guys ask me about this one and that one and I can't remember them. My PTSD blocks them unless something triggers an entrance. Not good. Better off hidden away.
gary
Posted: Saturday, April 22, 2017 - 08:14 PM UTC
Can't add to that
Except thanks for your service.
Posted: Sunday, April 23, 2017 - 08:44 AM UTC
Can't add to that
Been asked to write a book several times, but I still refuse to. Yet if I did, it would be nothing but funny stuff. No one needs or wants to know about my nightmares. But if you wanta talk about loading a barrel up with dead rats and shooting them due west; then I'm in.
I will tell you up front that the only reason I'm writing right now is from my second First Sargent. He busted my butt 24/7. He taught me the right way to do everything, and made sure I did everything his way. Glad it only lasted 15 months.
gary
KitMaker: 525 posts
Armorama: 266 posts
Posted: Monday, April 24, 2017 - 01:31 AM UTC
Can't add to that
gary
Gary, thanks for your service.
I'll buy you a six pack of Tiger beer with a glass of ice for that rat story...
-C. Earl
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Monday, April 24, 2017 - 05:11 AM UTC
Who knew this would turn into one of the most fascinating threads I ever saw ?
J
Posted: Monday, April 24, 2017 - 10:20 AM UTC
Can't add to that
gary
OK, and I swear up on a stack of bibles it's the truth.
The guy on phone watch is also tasked with emptying the rat traps. These were small field rats and not the great big grey ones. On any given night we'd fill a two gallon bucket up with rats. Then in the morning, we'd have to bury them. I was on LZ West for about a month, and it was a three gallon bucket every night. Well after awhile, we ran out of places to bury them.
Well we're the H&I gun one night. We always started out shoot charge one and two's greenbag. We'd watch the impacts on the east side of the Hiep Duc Ridge Line. Steadily increasing the powder charges with more range. We often shot these same targets five or six times thru the night, and at the sametime be shooting all over a 16 mile diameter circle. Usually about fifty targets shot six times each. Randy comes up with a scheme to get rid of the latest stash of dead rats. He stuffs a bunch of them down the muzzle end of the barrel. Well we figured they'd be out on the ridge someplace, and did it two or three times each night we shot H&I's. Come morning we'd see these guys on another gun crew walking around scratching their heads. Randy says we best play dumb as we might be headed strait to jail (this threat faced us at least once every six or eight weeks). Least we didn't have to walk a hundred yards or so to bury the rats!
Well the gun we shot over was manned by a bunch of Porto Ricans with a black guy named Milton (never knew his last name). Their AG was named Casanova (for real), and was always jacking with somebody. Randy slips over there one night and ties a rat to the lanyard. They were the H&I gun, so we knew they didn't have to shoot fire missions. Yet they had to shoot all "contact fire missions" like everybody else did. Sure enough about midnight we get a squad from the 196th in deep trouble. Shooting about three miles out, these guys were completely surrounded. When the call came out to fire, there was this blood curdling scream! The whole crew was running around in a circle screaming bloody murder. Milton was standing there with his hands ontop his head. They called the piece out and calls were coming in from Division on down. They told the division they had a hang fire, but of course they didn't. Randy whispers in my ear that we're for sure going to jail this time! The First Sargent drops by on his morning walk thru, and gets his beer. Comes over and tells us "no more rats!"
gary
KitMaker: 525 posts
Armorama: 266 posts
Posted: Monday, April 24, 2017 - 11:17 AM UTC
I love this!!!!
I also HATE monkeys. I was a merchant seaman and went down to the PI shortly after the base closure. we ported in Olongapo and worked with an ex-pat doing some of the SCUBA jobs. We were bunking with some Marines who were still on cleanup in the area, policing the base as it got parted out.
Every night there were these monkeys that would raid the latrine and garbage pit. Not the cute zoo-monkeys, but the big bite-your-face-off ones. If anyone hated them more than me, it was the Marines.
So, we brought in a batch of beer n' whiskey and shared with our mates, and on the 3rd night there, the monkeys were out in force. We were out at the fire pit and you could hear them on the ground, in the trees, and on the roofs. The Marine Sergeant had enough and took an M68 hand grenade, pulled the pin and stuffed it in a used MRE pouch (it was Beef Diced, with Gravy). He marched off into the darkness and came back a while later. We were all silent as we waited. Soon...came a faint 'pop' followed by a concussive THUD!
The jungle went quiet for a moment and the monkeys were all silent for the remainder of the night. We shipped out the next day, and on the way there was an Army intel guy on the docks. He asked "How was your escort?" I replied "Hot chow was a f*ckin' blast."
I owe you a sixer my friend.
-C. Earl
Posted: Tuesday, April 25, 2017 - 02:24 AM UTC
I love this!!!!
prior to Tet in 68, Bozo and I were put out on an LP one night. Maybe mid January. About one in the morning we got movement out to our 10 o'clock position. I hit the squelch button three times to alert the folks behind us (we were 250 meters out). The movement didn't stop, and hit the button again. Then there as a plop out front of us, and we took it for a dud grenade. I locked and loaded the sixty, and was ready to meet my destiny. Bozo gets hit up the side of the head with a rock the size of an egg! Then I get hit. Before it was over I must have been hit a dozen times, and who knows how many times Bozo got hit. The culprit was a bunch of rock apes!! Left us black and blue, but alive. In the morning we caught all kinds of ribbing and laughter while licking our wounds.
Was on another one that was really quiet. Got movement out front. I told the guy it might be rock apes again. I could see somebody crawling towards us, and I lit him up with the sixty. Almost instantly after that a bunch of wild pigs came running thru us. Another embarrassing event in my life of combat. We ate the pig by the way!
gary
KitMaker: 525 posts
Armorama: 266 posts
Posted: Tuesday, April 25, 2017 - 02:34 AM UTC
Same-day-sixty-pig.
Yum!
-C. Earl
