The rear bumper is assembled and ready for primer. A few things are not clearly illustrated in the assembly instructions but were pretty easy to adapt and figure out.
(PE-15) is the trailer power supply receptacle cover. The assembly instructions does not describe this part. I saw it on ref pictures on the internet so I wanted to include it on my model.
It would look too flat if I just glued it into position on the bumper so I adapted the receptacle part. First, I found a piece of guitar string (from my brother's guitar). It was just about the right thickness for the spring loaded hinge. The receptacle was a stack of 3 (PE-6) parts that is for the M1009 kit. (The same PE set is included in both the M1008 and M1009 kits) Then I glued (PE-15) on top. It looks about right now.
The diamond plate (PE-11) slightly over hangs the center area of the rear bumper. I suppose I could have filed it flush with the contour of that cavity after I glued it in place but I didn't.
(PE-9) is not described in the M1008 assembly instructions but it looked like it belonged over (PE-10) based on internet ref pictures. However, (PE-9) is described in the assembly instructions for the M1009 kit.
Rear bumper assembly is complete with exception to the tow shackles. I glued four rivets from a Meng set. Two on each end.
Thanks for looking
