I worked a bit on the Panhard, to get it closer to the finish line. The louvre grills are installed, but yet need to be adjusted and lined up. Their installation proved tricky for me at least and extremely time-consuming.
The left side is still not aligned perfectly and somehow the louvres are a bit low by about 1mm... Not sure. The right side needs some realignment fixes, but is mostly ok, I need to wash off all the dust and dirt, I might bathe it?!?. Also part 10 of the kits are 0.5mm short in my opinion, you can notice the mini gap on the top right louvre frame. (I got it all with 90 deg angles (along the sides), so wrong bending can't be the error.
At first I thought I did not like the interior, but after comparing pictures of WW2 and such, it is actually quite ok. Will see what a layer of paint is doing to it.
As time passed, the turret interior got some upgrades. It is left fairly plain by ICM and if you want to depict the turret rear doors open, some extra detail is almost needed. I have added some detail to the traverse gear. The left side needs some more detailing and the valve wheels to the right of the gear still need to be added.
The original French photo. I need to find a way to replicate the turret ring teeth....
For the doors I started by drilling out the vision and episcope slits.
Then I added the episcope to the left door and door handles, locks and gear. As I found the drawings and designs of the roof search light in the OKH report, I have added the internal fittings for it also.
The front also received an episcope and the roof Gundlach periscopes received an upgrade. There is no interior detail included and as such I added some crude and basic stuff, hinting at detail.
Some vehicle shots:
The door is actually locked in place at the 3rd (last possible slot of the machanism - see below)
A later APX3 turret version in France, with Gundlach periscopes on top and the episcope visible on the inside of the right rear door. Also the fighting compartment's door is painted on the inside like the outside on this Panhard, while there are many others with white colour:
Have a good day, feel free to spot errors.
/Stefan
Sources:
*) WarWheels -
http://www.warwheels.net/** CharFrancis -
http://www.chars-francais.net
