The ridge over the drivers visor is a rain deflector.
If these are all the same tank #3 would be the first, early no applique, #1 would be second, rebuilt with applique and #2 would be third.
Same vehicle?
m4sherman
KitMaker: 1,866 posts
Armorama: 1,808 posts
Posted: Thursday, June 01, 2017 - 06:56 PM UTC
Mrclark7
KitMaker: 503 posts
Armorama: 477 posts
Posted: Sunday, June 04, 2017 - 10:11 AM UTC
The areas I focus on is that above the light you see two holes on the faceplate instead of a trapezoid cut into it.
No plate around the machine gun port.
And the weld seem is very different between the front and side hull plates joint.
RobinNilsson
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Sunday, June 04, 2017 - 11:58 AM UTC
This image shows the two small holes hiding inside that cut-out:
Pz IV E (brand new ??)
The thing that puts question marks in my head is the joint between the up-armoured sides and the up-armoured front.
In one of the images it is obviously and add-on plate on the front but the other image shows a smooth corner.The smooth corner looks as if the additional armour has been integrated in the hull front (which would mean that it is two different vehicles)
/ Robin
