So here’s the provisional set-up – sharp eyed lurkers will note that this dio wouldn’t be possible without the generous support of National Geographic(s)...
Nearly done with the bases, as seen from the 3 camera angles...
The scrub’s dubiously labelled “Ground Cover Turf – Golden Straw” from Wee Scapes (Simi Creative Products)...maybe they should change their trading name too. But I bought it years ago based on what I could see in the pack rather than the description, it looks OK-ish & will get moderated further by a sprinkling of loose soil which will also blend all joins, with some paler soil for the convoy’s t*re tracks.
Leutnant Rudel finally agreed to some fresh test-flights after the recent scare (albeit subject to some rather unrealistic safety conditions as seen below) in order to try out different camera angles & see how it looked against the groundwork. With the big bird it’s a particularly tricky equation comprising relative distances between camera/plane/base; meteorology + orientation + sunlight strength + shadows; ideally eliminating wire visibility when it’s rigged properly (next task); getting the prop spinning (the task after that); and then there’s always random lorikeet shadows...
That shadow in the 3rd pic is way too big, maybe I can use the smaller plane to substitute its own shadow instead. Here’s the latter for comparison & alternate shots, suspended + prop-spin...
I’m beginning to figure out how to fade out the fishing lines during photography – either swinging the plane & shooting from further away on a slightly slower shutter speed (to blur the lines as well as the plane)...
...or on a higher shutter speed with the plane closer & in sharp focus so that the lines are not...
Easy to say, not so easy to achieve especially in the latter case because if the speed’s a fraction too fast the spinning prop “freezes”. I’m still using just Paint to mask out any lines that remain but if that doesn’t cut it hopefully Michael K can help out with Photoshop, despite my reservations it’s no different to what I’m doing anyway.
And that concludes this phase of prep - unless I’ve forgotten something which is always possible. There’ll be a couple of bonus features to surprise but I’m keeping those under wraps as they're still in experimental mode, so now it’s time to go dark & pull it all together. Lots of work still to do, maybe a few weeks before I’m ready to launch. Meanwhile thanks for looking in so far...
https://www.youtube.com/watch?v=GGU1P6lBW6Q
