How many of you have partially built models..
ReluctantRenegade
Wien, Austria
KitMaker: 2,408 posts
Armorama: 2,300 posts
Posted: Sunday, January 07, 2018 - 07:24 PM UTC
I think wives (or whatever...) can be happy that at least it's a hobby that isn't too expensive (compared to say cars, motorbikes, boats)
Well, unless you happen to have one of those (or similar) hobbies in addition to modelling...
spongya
MODELGEEK
Budapest, Hungary
KitMaker: 2,365 posts
Armorama: 1,709 posts
Posted: Sunday, January 07, 2018 - 07:45 PM UTC
Right now? I have 2 kits that were started 10 years ago... and 3 more I need to finish before I can start a new model
I am slowly working off my stash (I hope).
Photobug12
KitMaker: 4 posts
Armorama: 2 posts
Posted: Sunday, January 07, 2018 - 09:23 PM UTC
RobinNilson,
Excellent tips on masking! I have been struggling with this forever it seems. Will try some of these techniques. Builds go fine then I attempt to paint and wind up repainting things 3 or more times because of errors that happen!
Tried Silly Putty, leaves a residue. Tape always bleeds underneath, lightly pencil in the lines and the pencil shows through in places. This is why I get discouraged and it takes me months to complete a model.
Thank you again!
easyco69
KitMaker: 2,275 posts
Armorama: 2,233 posts
Posted: Sunday, January 07, 2018 - 09:30 PM UTC
i have apx ...25, 3/4 built kits lol
Seahawk
KitMaker: 61 posts
Armorama: 56 posts
Posted: Sunday, January 07, 2018 - 10:56 PM UTC
I have three at the moment in various stages, I always seem to have two to three going at once due to build, paint, weathering cycle. AKA - I will be building a kit while painting say an aircraft cockpit, while weathering some armor. Or have a 90% completed armor and working on indie link tracks.
It also keeps it fresh bouncing from one topic to another
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Monday, January 08, 2018 - 12:04 AM UTC
RobinNilson,
Thank you again!
Remember the single most important of all my suggestions:
Try It On Something Else First!
You can't ruin a sheet of plastic, discarded CD-case or whatever but it is possible to wreck an almost finished model. Experiment on scrap plastic, food containers or whatever until You find a method the works for You.
/ Robin
Kevlar06
KitMaker: 3,670 posts
Armorama: 2,052 posts
Posted: Monday, January 08, 2018 - 04:49 AM UTC
RobinNilson,
Thank you again!
Mark, to keep paint from bleeding under tape, use an old modeler's trick and spray a gloss (for canopies and clear parts) or a flat clear-coat over the tape first. It will seal the edges and keep paint from crawling underneath. I also like to use a small balsa rod around the tape to seal it before applying the clear.
VR, Russ
cabasner
Nevada, United States
KitMaker: 1,083 posts
Armorama: 1,014 posts
Posted: Tuesday, January 09, 2018 - 06:34 PM UTC
Russ, can you clarify how you use the balsa rod for sealing, please?
Kevlar06
Posted: Tuesday, January 09, 2018 - 08:24 PM UTC
Curt, I use a 1/4 inch square balsa "rod" sharpened on one end to burnish down the edges of the tape before spraying the clear to seal the edges. Guess I didn't make that clear. I use various types of wood dowel (I make a lot of tools out of various lengths of dowel and/or wire-- by shaping them with a Dremel tool-- everything from specialized putty and glue applicators to scrapers and aircraft rigging aids). I use the balsa dowel for burnishing tape down on canopies because balsa is softer and there's less danger of scratching the clear plastic. Eventually the balsa wears out, but a 3 foot length of balsa can make lots of "burnishers". Balsa seems to be getting harder to find though in my area as the R/C modelers are opting for carbon fiber rod-- but it to is great for making tools! I use Tamiya tape exclusively for masking canopies, or Eduard masks when I can get them.
VR, Russ
cabasner
Posted: Thursday, January 11, 2018 - 02:29 AM UTC
Thanks, Russ. That’s what I figured you meant, but wanted to be sure!
Smias04
Aitoloakarnania, Greece / Ελλάδα
KitMaker: 3 posts
Armorama: 3 posts
Posted: Thursday, January 11, 2018 - 05:57 PM UTC
I first started building models back in 1994. Planes in 1:72-1:32 but after a year i went on 1:35 scale tanks.
I think the models i have completed are something like 40-50, although i don't have them all with me, some are in my old house, some in the place i work/my job but none of them in the place i live now..
As for the incomplete they are about bouble compared to what i completed..!
I did a pause back in 2003 and started agian in the end of 2012, but still nothing ready..
Zhivago
Massachusetts, United States
KitMaker: 109 posts
Armorama: 97 posts
Posted: Thursday, January 11, 2018 - 08:05 PM UTC
I generally work on two models at a time, which means that they’re both in my dining room table work area. If I was to attempt to work on three or more at once I’m pretty certain that my head would explode. One of the present projects (Anakin Skywalker’s pod racer; it was supposed to be finished by the end of the SciFI III campaign. You can guess how that went) is about 2-3 hours from completion. The other one (a Takom Whippet Mark A for the WWI Armor campaign) is just started.
My stash consists of 12 kits kept in a closet. One of those kits (a Lindberg Gee Bee racer) is so bad that I can’t bring myself to finish it, even though it is SO CLOSE to completion; at the same time I can’t bring myself to throw it away, given the hours that I spent scratch building and reworking the kit. In all of my years of building, this is only the second instance of its kind for me (the first was many years ago—a Tauro A7V tank which was THAT bad to build [and I did throw that out!]). I always open a kit when I get it—you know, to do the exciting-new-toy inspection kinda thing, but I NEVER start the kit without intending to finish it fairly soon and never as a third or fourth work-in-progress. Just can’t do it!
Removed by original poster on 05/13/19 - 22:03:20 (GMT).
cabasner
Posted: Saturday, January 13, 2018 - 06:15 AM UTC
I have found that I get really discouraged at my own work. If I do something to mess up a kit, either make a mistake in the build, or just do a messy job at building, I get really unhappy and seem to want to give up on that model. I've got many that are in their boxes for that reason. I haven't got any that were badly engineered, at least not yet.
KruppCake
KitMaker: 401 posts
Armorama: 387 posts
Posted: Saturday, January 13, 2018 - 06:33 AM UTC
I’m the same way, but over time I’m learning to accept that no model will be 100% right to its builder and that fixing the flaws or mistakes, that are either already present or that you make, turn you into a better modeller and improve your skills. Fixing gashes, scratches, bad paint jobs, misalignments, etc, is valuable experience, and over time you’ll start to be happy with your repair jobs. I have a flak 88 that to me looks amazing now, but if you saw the in progress photos you wouldn’t think it’s the same model. I had primed and painted the entire thing carefully, with camouflage, only to see after that I had missed 4 very large and obvious seam lines because I had initially thought there were weld lines on the real thing. I took off the paint and primer completely from those parts, repaired the seams, and then re-did everything.
When doing models now I see it as my objective to physically manipulate the work in front of me in any and all ways necessary to make it look good. Sometimes that means a ton of repairs to stuff that started out just fine.
Monsoon
KitMaker: 81 posts
Armorama: 69 posts
Posted: Saturday, January 13, 2018 - 07:03 AM UTC
I have a simple rule that I follow; never start a new kit until the one I'm working on is finished. I never break this rule, so I don't have any started kits in the pile.
That's just crazy talk.
KruppCake
KitMaker: 401 posts
Armorama: 387 posts
Posted: Saturday, January 13, 2018 - 07:13 AM UTC
Yea that makes no sense. Maybe he meant once he’s started 20 he won’t start another one until one is done.
Jmarles
British Columbia, Canada
KitMaker: 1,138 posts
Armorama: 953 posts
Posted: Saturday, January 13, 2018 - 08:42 AM UTC
Darn. I forgot I had a shoebox with a few started kits in to add to my "to do" list.
Also my new years resolution to not buy new kits lasted a little over 24hrs. I bought a Tamiya Panther G and a Miniart street for a buried Panther dio. I also bought a bag of bricks and a few other doodads. At least it should build quickly and I might use the tracks and wheels for another kit. And a Trumpeter KV2 for an improvised "Bergepanzer KVII (r)" - the turret is for a bunker dio. And the Tamiya German Soldiers at Rest for said bunker. And a Cyberhobby German railcar. Oh well! Such is life!!
BunkerBuster
KitMaker: 157 posts
Armorama: 122 posts
Posted: Sunday, January 14, 2018 - 10:39 AM UTC
I have somewhere around 25 started. I love to build, but have a hard time getting motivated to paint.
I'm still in recovery from AMS that hit me about 15 years ago. I ended up taking a 14 year break from 2003 to 2017. In that time, I got into some very expensive hobbies (woodworking and building AKs).
Got back into modeling a year ago to ease the hobby financial burden for awhile. I missed so much while I was away. I've taken steps to avoid a relapse of AMS. Basically no crazy aftermarket and only scratch building minor stuff when necessary.
Striker
Wisconsin, United States
KitMaker: 94 posts
Armorama: 40 posts
Posted: Sunday, January 14, 2018 - 12:00 PM UTC
I've got 5 in different stages of building. My halt is mostly due to a big uptick in miniature gaming and the hundreds of miniatures to paint up. I'm slowly geting back to the mits though.
