Tank losses to air attack
urumomo
KitMaker: 675 posts
Armorama: 667 posts
Posted: Tuesday, May 29, 2018 - 12:42 AM UTC
So what specifically are you refuting , Robin ?
Keep your emotions out of the answer , please .
The internet has made it possible for various strange people to make their voice heard by a worldwide audience.
cough cough
I don't see any specific counter to the video's numbers , nor does the video maker dismiss the effectiveness of air attacks on morale , maneuvering etc .
Lke Gerald inquired : Did you watch the entire video ?
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Tuesday, May 29, 2018 - 01:59 AM UTC
cough cough
Thank you for picking one single sentence out of those that I wrote.
I was merely stating that I do not take everything at face value.
The analysis of F-86's attacking Soviet tanks was interesting, the AA had a high probability of hitting a fast moving target while the aircraft had huge difficulties hitting the tank.
I do not have a copy of the book referred to in the video and I do not have access to the sources upon which the book is based so I can not verify or disprove anything of what the book says.
I am simply sceptical about a lot of things pushed out in social media. Take the Sherman and tank warfare "expert" and all his claims about that tank as an example.
I am not quite sure that I understood how aircraft could have such a devastating effect on non-armoured vehicles while they seemed almost totally unable of hitting a tank.
In the beginning he presented hit ratios, gunfire hit with 25% which I consider to be OK.
Rockets were 89% within 140 meters but I failed to pick up percentages for shorter distances. How many were within 35 metres for instance.
I assume that the accuracy ratio for bombs is based on bombs actually dropped against tanks. Level bombing from high altitude isn´t very accurate so I presume that those bombs have been excluded. It would have been interesting to see accuracy numbers for bombs dropped at low level or dive-bombing.
The comment that AA is more about scaring the aircraft off target than about actually hitting the aircraft. Especially when contrasted with the calculations about F-86 vs JS-3 ...
/ Robin
babaoriley
KitMaker: 195 posts
Armorama: 179 posts
Posted: Tuesday, May 29, 2018 - 02:21 AM UTC
"The Bismarck was not sunk be the Royal Navy, they simply forced Lindemann and Lütjens to sink her themselves ...."
That's what might be called a distinction without a difference. Even if the Bismarck's crew fired scuttling charges, the ship was a smoldering wreck incapable of causing further harm and was about to be sunk whatever Bismarck's crew did. It's much like tanks not making it to the battlefield because of repairable damage or destroyed bridges or the loss of supply vehicles--a mission kill is almost as good as destruction. In the case of Bismarck, the theorized scuttling occurred minutes before the RN would have accomplished the same thing.
urumomo
KitMaker: 675 posts
Armorama: 667 posts
Posted: Tuesday, May 29, 2018 - 02:40 AM UTC
/ Robin
No Problemo
So , all this protestation is based on your feelings and not facts to the contrary ?
K
BTW - you infer A LOT from this guy's video ( maybe the accent remind you of someone you dislike )
The example of the captured Panther set into a field , painted white - attacked by ,, how many was it fighter-bomber ? ,, static , painted white & knowing there is no risk from ground fire and the hits were pretty minimal ,, pretty much sums it up .
sgtreef
Oklahoma, United States
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Tuesday, May 29, 2018 - 03:24 AM UTC
And don't leave those bad ass Helicopters out neither.
When I was in most were from Nam ,and said they loved when spooky was called in, or the F-4's.
18Bravo
KitMaker: 7,219 posts
Armorama: 6,097 posts
Posted: Tuesday, May 29, 2018 - 04:05 AM UTC
So we're basing effectiveness on number of hits versus number of rounds/rockets (whatever) fired?
Ever seen the research into the number of 5.56 rounds fired for each "kill" in Vietnam? Similar arguments - suppresive fire was part of it, and has to be taken into account, kept their heads down and kept them out of the fight, yada, yada, yada...
If you doubt what an aircraft can do to a tank, why not climb inside a T-55 and let an A10 take one pass at it. See how your theories hold up. I've witnessed it firsthand.
urumomo
KitMaker: 675 posts
Armorama: 667 posts
Posted: Tuesday, May 29, 2018 - 04:25 AM UTC
What theories ?
Who are you talking to ?
The video is about concrete numbers from WORLD WAR TWO .
.Like , no JDAMs , or A-10's or Strike Eagles .
The guy never says that airplanes aren't dangerous or totally ineffective or any of the inane , hyperbolic crap that Robin has conjured up .
barkingdigger
KitMaker: 3,981 posts
Armorama: 3,403 posts
Posted: Tuesday, May 29, 2018 - 04:44 AM UTC
Best to be careful with those figures - I had a cousin who was personally responsible for spannering the "rounds fired" part of the equation! He serviced helicopters well away from the front line, but told me that every month they had to hand in last month's policed brass along with other "recyclables" to prove they were using up what the Army expected them to use in a war zone. But without anyone to shoot at, they struggled to use up their ammo. So once a month he and some buddies had to load up a truck with the unused ammo, form a circle in some empty jungle, and spray the trees til the barrels glowed and the brass piled up. Laying down a tarp first apparently made collection a whole lot easier...
Never forget there are lies, there are damned lies, and then there are statistics!
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Tuesday, May 29, 2018 - 12:32 PM UTC
In the beginning of the video he shows statistics for hit/miss for bombs, rockets and guns.
The guns supposedly hit with 32 out of 120 which comes to 26% (let's say 25%) but the rest of the video mostly talks about the rockets and to some extent on the bombs.
Could the 20 mm Hispano, the Typhoon carried four of them, penetrate the roof of a German tank? Pz IV had 10-12 mm on top and penetration for AP used to be roughly the diameter of the projectile. The 12 mm at a 45-degree angle becomes 17 mm so maybe the 20 mm could punch through.
I would have like to see this aspect discussed in the video.
/ Robin
Kaktusas
Vilnius, Lithuania
KitMaker: 196 posts
Armorama: 196 posts
Posted: Tuesday, May 29, 2018 - 04:17 PM UTC
I agree with Robin on this one. It is easy to judge and focus on details, but this way you loose the focus on whole picture.
With such approach, for example V1 and V2 was complete failure, and waste of money. I wonder why they bothered chasing those V1's after all.
Hmmm, what am I refuting?
First of all I have a deep scepticism against a lot of things being said/shown on Youtube. Some producers have their own agenda, some just want to make a buck, which is perfectly OK but sometimes it leads to following the old rule for newspaper producers: Never let the truth get in the way of a good story.
Agendas come in many different forms, religious, political, economical, conspiracy theories et.c.
In short: I tend to be sceptical.
I have a hard time believing that the Ju 87G, the Il 2 and various other airplanes used for the ground attack role were total wastes of time and effort. One airforce may be misled but so many at the same time? Did they copy each others mistakes?
When is a weapon system a failure? When it misses in how many percent of the cases? Is it scary enough if a fighter-bomber can take out a tank in 10% of the attacks?
How many of the projectiles fired by fighter planes against other aircraft, regardless of type, did actually hit and kill something? What is the percentage of fired naval artillery shells actually hitting their target?
In modern times the hit ratios are climbing up but we still have not reached 100%.
How many of the bullets fired by the MG 42, and others, actually hit something else than the countryside?
Trying to prove something by showing that the claimed kills were actually far higher than the actual kills doesn't cut it with me.
If the appearance of a fighter bomber in the sky made everyone run for cover then that plane is efficient in some sense. If the enemy is hiding in the bushes then they are not moving toward the front.
This is in the same general area as but not quite the same thing as:
是故百戰百勝,非善之善者也;不戰而屈人之兵,善之善者也
One possible translation:
"Hence to fight and conquer in all your battles is not supreme excellence; supreme excellence consists in breaking the enemy's resistance without fighting"
If the beancounter fights a war he counts the number of enemy units destroyed, another way is to count the number of enemy units prevented from fighting at all.
If fighter bombers in the air can halt enemy movement then it is a clear win in my books. The tanks can rust to death for all I care as long as they do not roll onto the battlefield.
With some clever use of statistics it could be shown that most weapons systems were inefficient. By restricting the evaluation criteria it could be shown that many useless systems are efficient. U-boats were a deadly threat to shipping but most freighters got through, the number and size of sunk ships were sometimes exaggerated by the u-boat captains. Was the u-boat efficient or not?
As long as the video producers get a lot of clicks/views ....
/ Robin
Bravo1102
KitMaker: 2,864 posts
Armorama: 2,497 posts
Posted: Tuesday, May 29, 2018 - 04:27 PM UTC
/ Robin
Just for the heck of it I looked up the armor penetration for M8 armor piercing ammo used in a 50 caliber machine gun. 17mm at 90 degrees at 100 yards. Depending on angle of attack and altitude the roof of many tanks would sustain some penetration.
At the very least it would inconvience the crew in the rain with all those holes in the roof.
ReluctantRenegade
Wien, Austria
KitMaker: 2,408 posts
Armorama: 2,300 posts
Posted: Tuesday, May 29, 2018 - 04:48 PM UTC
We need to distinguish between DIRECT and INDIRECT effectiveness of WW2 fighter-bombers against tanks.
In terms of DIRECT effectiveness, it is safe to say that airstrikes did not meet the expectations: direct hits with bombs and rockets were quiet hard to achieve due to inaccurate aiming and/or weapons, especially on a moving target; guns and machine-guns were more effective in hitting the targets, however their week penetration potential limited the chances to knock-out (let alone destroy) a heavily armored target such as a tank.
Even the heavily armed Ju-87G (2x37mm guns) and Hurricane Mk.IID (2x40mm guns) pilots were instructed to engage tanks by aiming at the rear-horizontal surfaces of the tank and the turret-roof when possible, usually using the 'walk-in' method (although later, special AP ammunitions did allow attacking low also from the sides with good chances of knocking tanks out). In case of the
Il-2, the brilliant 'circle of death' attack method developed specifically for the 'Sturmovik' was a particularly lethal combination against ground-targets. In other words, it was rather the combination of efficient tactics/right aircraft/trained crews that made the 'Sturmovik' so effective in ground-attack role than the capabilities of the aircraft itself.
In the INDIRECT role however, fighter-bombers proved incredibly effective against anything that moved on the open without sufficient air-cover, be it infantry, soft- or hard-skins. In France, hordes of allied fighter-bombers caused havoc beyond enemy lines months before D-Day by constantly harassing German support lines, practically reducing day-time German troop-movements to zero. In many cases, fighter-bombers successfully held-up (or even prevented) German units from entering combat-zones (let alone engaging the allies) by destroying major transport-hubs, supply-trains, bridges and the extremely vulnerable auxiliary-vehicles carrying the absolutely essential fuel and ammunition.
In the Battle of the Bulge, after the skies cleared, allied fighter-bombers didn't attack the heavily armored tanks, but rather their supply-vehicles. Without fuel and ammunition, many German tank-crews were forced to abandon and destroy their own vehicles.
Another important side-effect of the fighter-bomber was their impact on the accompanying infantry. In case of an aerial attack the infantry was forced to seek cover, leaving the tanks unexposed on their own. Many inexperienced tank crew-members bailed out during a 'Jabo' attack just to be killed by bombs, rockets and MGs fire that otherwise would've been protected from inside the tank. Re-organizing an attacked column and resuming movement took considerable time and effort even if the damage was negligible, let alone following a successful attack. Because of the constant fear of fighter-bombers, the fighting power of many German units was significantly reduced, long before engaging in actual combat.
Apparently fighter-bombers contributed more effectively to indirect neutralisation of tanks rather than to their direct destruction. In other words, the fighter-bombers' major contribution to the war-effort seems to be arresting movement and suppressing of armored-formations consisting of tanks, supply-vehicles and accompanying infantry units. Just my 2 cents...
ReluctantRenegade
Wien, Austria
Posted: Tuesday, May 29, 2018 - 04:57 PM UTC
Could the 20 mm Hispano, the Typhoon carried four of them, penetrate the roof of a German tank?n
Would be better to aim at the engine-deck. Mind you, in many cases a knocked-out tank is just as disabled (and useless) as a completely destroyed one - or a tank out of fuel and/or ammunition for that matter...
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Tuesday, May 29, 2018 - 05:16 PM UTC
War is complete failure and total waste of money
/ Robin
Bravo1102
Posted: Tuesday, May 29, 2018 - 06:14 PM UTC
The V2 was anything but a waste. The men who worked on it were grateful for the funding to build it and targeting London was incidental to their real intentions.
By their own account, the German rocket scientists were always focused on space. But then some said nuclear power was the goal and the nuclear bomb was the byproduct produced to get nuclear power.
Scientists can be such idealists.
ReluctantRenegade
Wien, Austria
Posted: Tuesday, May 29, 2018 - 07:00 PM UTC
The M2 AP cartridge is able to penetrate 19mm of steel at 90 degrees from 500 meters, the M8 API 16mm from similar angle and distance.
The P-47 with its eight 0.50 cal MGs converging at around 400 meters combined with the added velocity of the plane was able to deliver a significant punch.
In reality, a single 0.50 round could do little damage to the turret-roof of a PzKpfw.IV or V (12 and 16mm respectively), however multiple rounds impacting near the same spot will eventually weaken the armor and penetrate. Now, in order to deliver such a shot in combat conditions one has to be extremely talented and/or lucky...
With a 20mm (or more) gun loaded with AP rounds the chances are higher of course.
Biggles2
Quebec, Canada
KitMaker: 7,600 posts
Armorama: 6,110 posts
Posted: Tuesday, May 29, 2018 - 07:36 PM UTC
But rounds fired from a strafing aircraft didn't strike at 90 degrees. More like 45 degrees, or much less, making the 19 mm armor effectively thicker.
ReluctantRenegade
Wien, Austria
Posted: Tuesday, May 29, 2018 - 07:46 PM UTC
Of course, these are standard values to be used as reference only. The optimal diving angle in AT role was around 30 degrees. That’s why I wrote previously that aiming at the engine deck is a better bet: destroying the cooling system of a tank forces the crew to abandon even if the rest of it completely intact. Depends on the on the actual battlefield-conditions, the tank is temporarily or permanently, but out of action.
srmalloy
KitMaker: 336 posts
Armorama: 298 posts
Posted: Tuesday, May 29, 2018 - 08:28 PM UTC
In terms of DIRECT effectiveness, it is safe to say that airstrikes did not meet the expectations: direct hits with bombs and rockets were quiet hard to achieve due to inaccurate aiming and/or weapons, especially on a moving target; ...
True, but getting ordnance close enough to break a track achieves much the same effect when attacking a unit in motion; the time necessary to fix the track takes the tank out of whatever action the tank would have taken part in, and if the unit was retreating, the crew is likely to abandon and destroy the vehicle rather than hanging around to repair it. Not that having to put ordnance close enough to the tank to damage a track lowers the bar that much, but it's still easier than trying to punch through the tank's armor.
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Tuesday, May 29, 2018 - 08:29 PM UTC
Or the fuel tanks.
KurtLaughlin
KitMaker: 2,402 posts
Armorama: 2,377 posts
Posted: Tuesday, May 29, 2018 - 08:45 PM UTC
What's the argument in the video, and here? I watched as much as I could stand and it appeared that the video's point was that aircraft did not kill huge numbers of tanks in WW II, despite what video games might show. Is anyone really contesting this point?
While this is statement is true, it does not mean that aircraft, particularly fighter bombers, were not useful weapons against ground forces, including tanks. Tanks are less effective when buttoned up, whether the cause is artillery fire, strafing, bomb and rocket explosions, or infantry small arms fire. Heavy volumes of fire from aircraft can further reduce effectiveness by damaging vision devices, cutting antennas, damaging running gear, and breaking tracks. While these may be easily repaired they still affect the ability of the tank to perform its mission, and may be part of a cascade of misfortunes (crew killed by artillery fire when repairing tracks; damaged sprocket fails and immobilizes tank while engaged with enemy armor, etc.) that eventually degrades the enemy armor forces.
Who is questioning this?
KL
Bravo1102
Posted: Tuesday, May 29, 2018 - 08:46 PM UTC
The turret top armor as stated earlier was 10-12mm. Also the range would be considerably closer. An altitude of 100 feet, then a range of a few hundred yards and you're going to get holes. Ever see a Sherman used as an aircraft range target for 50 caliber? Dings all over and holes in the top. Not Swiss cheese but enough to unnerve a crew and make it leak in the rain.
Remember that tank crew were often told it was safer to be under the tank in air attack and not in it.
ReluctantRenegade
Wien, Austria
Posted: Tuesday, May 29, 2018 - 09:55 PM UTC
Another factor that contributed to the less-than-expected kill ratio of WW2 fighter-bombers in AT role is that actually none of them (save for the Hs-129 I think; correct me if I'm wrong) was designed as a designated tank-killer: the Stuka was a dive-bomber, the Sturmovik was a ground-attack aircraft, the upgunned Hurricane, the Typhoon, the P-40 and the P-47 in ground attack squadrons, the A-36 - all started out as fighters.
Somebody mentioned earlier the A-10: well, the big difference is that the Warthog was designed ground-up with the sole purpose of killing tanks to offset the huge numerical advantage in armor possessed by the Warsaw Pact.
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Wednesday, May 30, 2018 - 01:54 AM UTC
Topside armour for some German tanks
Pz III, different variants
Turret: 10 to 12 mm
Superstructure: 17 to 18 mm
Hull: 16
The Ausf A through D had 10, 10 , 5 but they are not relevant
Stug III, variants
Superstructure: 11 or 17 (different surfaces)
Hull: 16
Pz IV, variants
Turret: 10, 15 Ausf H, 18 Ausf J increases late in the war
Superstructure: 12 mm
Hull: 5 increased to 10 in Ausf D
StuG IV
Superstructure: 11 mm, 20 late in the war
Hull: 10, 10 and 12 (different surfaces ??)
Pz V (Panther)
Turret: 16
Hull: 16 with 40 and 16 for Ausf G, reinforced areas?
The Ausf F was designed to have 40 on the turret (I wonder why??) with 25 on the superstructure and 16 to 30 on the hull. Maybe they had recycled armout they needed to reuse or the quality of the steel was deteriorating.
JagdPanther had 25 and 16 on the topsides
Tiger 1: 25 mm on all topsides
Tiger II: 40 mm topsides.
The large majority of German tanks had topsides below or well below 20 mm. The JagdPanther and Tigers went above 20 mm.
I wonder why they increased the thickness of the topside armour later in the war? Deteriorating armour quality or perceived threat levels?
/ Robin
urumomo
KitMaker: 675 posts
Armorama: 667 posts
Posted: Wednesday, May 30, 2018 - 02:16 AM UTC
Same reason all the armor thickness was going up .
More and more powerful weapons to defend against .
I wouldn't use armor thickness as too much of a yardstick - look at the Maus .
It has no bearing on the actual hit / kill rates which is what the video is about .
