Nice!
Some text about GAZ-34 from a Russian website(translated by Google translater and edited by me):
"First 2 prototypes were built in 1964,they used the pre-production series GAZ-66 cab and were distinguished by 4 horizontal openings above the early type grille.The last 3 were built in 1967 and used the standard GAZ-66 cab.
Two of the few original elements of the GAZ-34 were the elongated spar frame and an all-metal cargo platform with wheel wells and an internal length of 4100 mm (+800 mm compared to the GAZ-66), but of the same width (2050 mm) and with the same sides.
Three longitudinal folding benches providеd seating for 27 people and a tarp with observation windows and ventilation valves were mounted on.
Original feature of all five test vehicles GAZ-34 were some insignificant differences in the design, configuration and dimensions of each sample. As a result, the wheelbase between front and middle axles ranged from 3445 to 3453 mm, the wheelbase of the rear bogie — 1245 or 1250 mm, overall length was between 6425 - 6435 mm, the front and rear wheel track - 1810–1815 and 1750– 1755 mm, clearance varied between 306 - 312 mm.
With an average curb weight of 5150 kg, the total weight of different prototypes ranged from 8260 to 8820 kg.
All these data come from official test reports, although it is likely that they were simply the result of permissible errors in measurements, because the tests of GAZ-34 machines were carried out separately on several routes from Moscow to Ashgabat and Ukhta, at different locations and at temperatures up to +42 ºС.
While undergoing tests, the trucks carried personnel, towed various trailers, mortars, a 122-mm howitzer M-30(weight 2.5 tons) and even an An-24 airplane.According to the test results, the GAZ-34 received a positive assessment and was recommended for commissioning, but with the organization in 1967 of the mass production of a more powerful ZIL-131 truck with similar parameters, the military’s interest in the new truck disappeared".
