Hi all,
I have decided to call time on this build, I could keep fiddling and tweaking but I think the gains made for the time involved would be minimal now,
As previously mentioned, this build was more of an experiment and, as such, I have learnt quite a bit, it’s not perfect by a long shot, but it has shown me that I have to work a lot on my technique,
I made some schoolboy errors, and worse, both whilst constructing the kit and whilst painting it, there are some elements that I think are okay, and others, like figure painting, that I am not happy with at all,
. Whilst Dennis and Brian have offered some excellent advice on face painting which will be invaluable in the future...thanks,
...I have messed these figures up to a point where I’d have to try and strip all the paint off and start again...anyway, enough of my ramblings,
Below are some images of the finished Conqueror, both off and on its base.
I’m no ‘nut & bolt’ counter,
, so cannot comment on the accuracy of the kit but, imho, the Amusing Hobby version of the Conqueror MK2 builds in to a nice-looking beast,
. Yes, it did take some initial work to clean-up and/or fill-in parts, especially on the lower hull and running gear. Some of the work possibly wasn’t necessary as a lot of it would be hidden, especially on a dirtied-down build.
Apart from some silly mistakes on my part and the taking care of some small and fiddly pieces there are, for what it’s worth,
, only two areas of the build that really need care and forethought, the first being the fitting of the upper bazooka plate. The instructions suggest you fit these in ‘Step 15’ of the build process, before the upper and lower hull are mated together in ‘Step 30’. However, I found that I had some difficulty fixing the bottom edge of the upper bazooka plate to the supporting arms previously fitted to the lower hull. Now this might be my fault,
, a better, more experienced builder might not have the same problem but, with hindsight, I think I would have fitted the upper bazooka plate after the mating of the upper and lower hull. The second was one of my mistakes,
, I decided to build the gun crutch prior to mating the upper and lower hull whereas the instructions leave this to the very last stage, ‘Step 31’. Work with the instructions on this one as going ‘off piste’ as I did could result in the rear mud flap, part of the upper hull, fouling the gun crutch when the upper and lower hulls are joined together...I was lucky this time.
Well, there you have it, the build is over,
, and I haven't gone totally insane,
. My thanks go to those people that have followed this build log and my special thanks go to those people that have taken the time to give encouragement and kind words, hints and tips, as well as feedback on methodology...you know who you are, cheers to you all,
G
