Sometimes, it just takes a little 'oomph' to get moving on a build that has stalled. It took me just that to get my Matilda finished, which I finally did in July of 2019. I have to tell you that seeing that tank finally finished is really, truly worth the anxiety. I had to really press myself, worried that the masking, over all those 'peaks and valleys' that are presented by the Matilda, wouldn't be effective. But trust me, it was, and didn't require that you be perfect in getting the tape down all the way. Even close is good enough, as long as you keep you airbrush as close to 90 degrees above the tape, so the spray will go 'straight down', so to speak, and I'm sure you'll find that this is fine. It was really worth the effort, though, seeing that tank in all 3 colors, really wonderful! I'm looking forward to seeing your tank all done, Caunter scheme and weathering in place. Realize, too, that weathering helps a lot with respect to any imperfections in the masking. I never posted any pictures of my completed tank, but suffice to say that I think it came out reasonably okay. I was happy with it, especially after the heavy duty desert weathering I did on it.
Keep on moving, Robert, and let's see your finished tank!!
