30th U-boat Flotilla
hemblecreations
KitMaker: 173 posts
Armorama: 110 posts
Posted: Friday, August 16, 2019 - 07:14 PM UTC
That is amazing.
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Friday, August 16, 2019 - 09:26 PM UTC
That is amazing.
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Friday, August 23, 2019 - 09:03 AM UTC
New quay side ,Entirely made from Blue Foam
And filled the space between the masonry with plaster.
Paulinsibculo
KitMaker: 1,322 posts
Armorama: 1,239 posts
Posted: Friday, August 23, 2019 - 09:14 AM UTC
What happened to your u boat bunker dio?
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Friday, August 23, 2019 - 09:18 AM UTC
Sold it
cheyenne
KitMaker: 2,185 posts
Armorama: 1,813 posts
Posted: Friday, August 23, 2019 - 11:02 PM UTC
Nice job Piet , keep going man !!!
Dioramartin
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Friday, August 23, 2019 - 11:29 PM UTC
This really is something else, fantastic. How did you work the blue foam - cut each brick (surely not?) or indent the mortar lines? Either way it’s perfect
panzerbrown
KitMaker: 6 posts
Armorama: 6 posts
Posted: Saturday, August 24, 2019 - 01:15 AM UTC
This looks amazing! When you can, could you please explain on how you scratch built the U-Boat? I’ve built the Bronco XXIII and always wanted to do the Accurate Armor VIIC but didn’t want to spend the money. Great work!!
Thank you.
Thank you.
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 24, 2019 - 01:46 AM UTC
Cheyenne ,Tim & Chris thanks guys !
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 24, 2019 - 02:12 AM UTC
This really is something else, fantastic. How did you work the blue foam - cut each brick (surely not?) or indent the mortar lines? Either way it’s perfect![]()
Tim,
Yes i did cut out all the stone facings separately.
First i pressed the foam with a steel scrubber and a stif tooth brush to get some texure .
Than i cut strips from a 3mm thick Blue Foam sheet with A strip cutter in to strips and cut them to size with my chopper ,
And glued them on with wood glue .
After it was dry,
I made some plaster and coverd it completly with my hands so every seam was filled wait for a minut or so..... and wipe it off with a damp cloth.
That's it
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 24, 2019 - 02:37 AM UTC
Thank you.
Chris ,
I got the deck made, bought several books and detailed plans.... and build it from plastic instead of wood.
The Accurate Armour is a solid piece of resin all the flood holes are closed up.....a real pain in the
You could also get the Scale 75 type 7 c bridge
https://scale75.com/en/figures-135/697-u-boat.html
safes a lot of work especially with all detail in the conning tower.
The deck part is the hardest part of the build,
if you want a later war boot it easier because of the simplified wooden deck .
but if you want an early to mid war boat i suggest to get a CNC milled deck from www.modellbau-wikinger.de .
''I see there closed due to maintenance ''
Get you self a set of plans
https://www.zvab.com/servlet/BookDetailsPL?bi=18464311050&searchurl=an%3Dk%25F6hl%2Bfritz%2Bniestel%2Baxel%26hl%3Don%26sortby%3D20&cm_sp=snippet-_-srp1-_-title2
Or simelar
and build it.
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Saturday, August 24, 2019 - 03:00 AM UTC
As I said before man,this build rocks!
I was wondering if you have to seal the blue foam before paint and if so,what do you use?
J
J
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 24, 2019 - 04:57 AM UTC
Jerry
Good old Vallejo primer will do the trick
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 24, 2019 - 05:06 AM UTC
Aded a nook for a ladder to make it look more interesting.
something like this.
or simple steel grips
jrutman
Posted: Saturday, August 24, 2019 - 06:04 AM UTC
Thanks buddy! Yes,that nook and ladder work very well.
J
J
panzerbrown
KitMaker: 6 posts
Armorama: 6 posts
Posted: Saturday, August 24, 2019 - 07:51 AM UTC
Thank you for the information! Again your work is amazing, I’m looking forward to see the final product!
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 24, 2019 - 11:54 PM UTC
Did the grips,
cheyenne
Posted: Sunday, August 25, 2019 - 01:11 AM UTC
Nice work Piet , good I see you chose the rungs . I live on the coast , wood and salt water don't mix . Treated tarred pilings ok , nowadays pt wood . The wooden ladder just didn't look right in a quayside setting . I also like the fact that the rungs are inset into the quay and not just there exposed and banged up against by ships and boats .
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, August 31, 2019 - 01:38 AM UTC
Last section added and primed,
Thinking off also adding a AA position with an Italian FLAK used by the Germans .
Next.... Slabs of concrete on the topside/road
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Saturday, September 07, 2019 - 01:17 AM UTC
All the greys,streaks and shading done with the airbrush.
letting it dry for a few days ,then it's time for washes and blending.
jrutman
Posted: Sunday, September 08, 2019 - 02:09 AM UTC
Very very nice!!
J
J
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Thursday, September 12, 2019 - 10:58 PM UTC
Jerry
Oil Paint wash, dark grey on top and a lighter grey on the side to accent the mortar,
Bollards in position (not glued in yet)
jrutman
Posted: Saturday, September 14, 2019 - 01:41 AM UTC
Nice progress man. Thanks for breathing life into the forum. I was about to start looking for the headstone.
J
J
cheyenne
Posted: Saturday, September 14, 2019 - 11:30 PM UTC
Beautiful work man !!! The sweet part is that it's all scratch built from your hands , right outta yer melon !!!
deerstalker36
KitMaker: 232 posts
Armorama: 218 posts
Posted: Sunday, September 15, 2019 - 11:10 PM UTC
Amazing build here
