Building a 16th. Panzer IV Ausf. F
KitMaker: 24 posts
Armorama: 24 posts
Posted: Monday, December 16, 2019 - 05:09 AM UTC
KitMaker: 24 posts
Armorama: 7 posts
Posted: Monday, December 16, 2019 - 06:31 AM UTC
Your work is phenomenal and I envy your attention to details.... but I in NO WAY envy what you are undertaking now with those tracks!!!!!
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Wednesday, December 18, 2019 - 03:42 AM UTC
I have the Track assembled in sections of 10
This will be easier to handle when painting.
Here is how I did it .
The Guide Horns are Hollow and go on the shoes a certain way.
Some of the Track pins wouldn't go in.
Posted: Wednesday, December 18, 2019 - 03:47 AM UTC
I used a #57 Drill Bit to ream out the holes.
Just a touch of glue to make shure the pin stays in.
Next to paint everything then the final assembly and Install.
Finished for now.
Donald
Posted: Wednesday, December 18, 2019 - 08:15 AM UTC
Painted
Next to join them all together.
Regards.
Donald
KitMaker: 24 posts
Armorama: 24 posts
Posted: Thursday, December 19, 2019 - 04:42 AM UTC
Looking good. What color metallic paint did you use for the tracks?
Posted: Thursday, December 19, 2019 - 08:07 AM UTC
I used Model Master Metalizer Gun metal Buffing with Steel for the rub areas.
Donald
Posted: Thursday, December 19, 2019 - 08:09 AM UTC
Here the Tracks and Front Extras are installed.
Finished for now.
Donald
KitMaker: 24 posts
Armorama: 24 posts
Posted: Thursday, December 19, 2019 - 08:24 AM UTC
I like the Buffing M M Metalizers, as you can buff it, leave as is, or seal it with your choice of clear. It appears you're leaving yours as is.
Posted: Thursday, December 19, 2019 - 09:35 AM UTC
That is correct, that way it can always be touched up.
Donald
Posted: Saturday, December 21, 2019 - 10:15 AM UTC
Here are the Side Ammo Bins, it really helps to have a Photo-Etch bender for doing this.
They just need some paint, I'll finish assembling them when I get the Ammo finished.
Now for the 3 Spare Tracks on the fender.
You really have to work it to get the mounts over the Track.
Then I placed the assemblies in position on the fender and glued the mounts to the track. (NOT TO THE FENDER)
Posted: Saturday, December 21, 2019 - 10:23 AM UTC
That's all for a while, I'm working on the Ammo next.
Regards
Donald
Posted: Friday, December 27, 2019 - 10:47 PM UTC
Well it took a while but I finally have the ammo finished.
These will go in the side bins, that's why I finished the ends.
The rest go in the verticle storage bins, you cant see the front half of the rounds, so there's no point in finishing them.
I have short pieces of sprue glued to the ends to make it easier to handle them while painting them.
Now to install them.
Donald
Posted: Sunday, December 29, 2019 - 04:23 AM UTC
I have all the Ammo loaded in their bins.
Here's how I did it.
Starting with the assembled Bins.
Yes I know this pic is a repost, it's to show how it all starts.
After painting the Bins I slid the rounds in starting with the rear most ones.
This is the 6 Round Bin.
Be shure the edge of the round is against the support block and clear of the end of the Bin edge.
Posted: Sunday, December 29, 2019 - 04:31 AM UTC
Like so.
Add the next row.
Add some liquid glue to the back side of the rounds.
It should look like this.
Posted: Sunday, December 29, 2019 - 04:38 AM UTC
Now after removing the paint on the mating edges install the outside cover.
It's a verry tight fit if you want to install the cover first.
Now for the other side bins, this went a lot easier.
The first layer.
The second layer.
Posted: Sunday, December 29, 2019 - 04:44 AM UTC
Posted: Sunday, December 29, 2019 - 04:50 AM UTC
Posted: Sunday, December 29, 2019 - 04:57 AM UTC
The inner upright bin 23 Rounds here.
Of course I didn't finish the pointy ends here either.
Finished for a while now.
Regards.
Donald
Posted: Monday, December 30, 2019 - 08:19 AM UTC
Posted: Monday, December 30, 2019 - 08:23 AM UTC
There's a thin line on each side where the upper armor mounts, if you mask it off it should make installing the upper armor easier.
Here's why I wish that I had left the rear fender parts off untill the fenders were installed.
I had to disconect them to get the fenders on.
Installed.
There's a small tab on the part that goes in a grouve as shown.
Posted: Monday, December 30, 2019 - 08:34 AM UTC
Posted: Friday, January 03, 2020 - 09:42 AM UTC
Man I needed that nap (Yahaaan)
Well any way I did get some more done.
I drilled and pined the small hatches on the driver & radio operators hatched.
Posted: Friday, January 03, 2020 - 09:46 AM UTC
Did the same for the drivers hatch, verry tricky here.
Not so good for the other one.
Hey I'm not purfect I show my screw ups along with what comes out right.
They give you the hatch for the G/H/&J models in the kit.
The hinges on the later hatch look a little bigger.
Posted: Friday, January 03, 2020 - 09:54 AM UTC
