My next step is to put the rear deck cover on. I quickly noticed that the kit part did not fit. The L shapes mounting lug on the deck was wider than the female mounting receptacle.
I ended up cutting the left side male mounting lug on the deck and now the cover fit fine.
I now installed the rear armored side plates for the rear deck.
It appears that the deck is longer, the side armor is shorter or I somehow did not fit the deck correctly.
I checked the front fit. Looks OK
I did a trial fit and the deck was too long and the upper hull would not sit flush with the lower deck.
I started by removing part of the rear hull plate.
That helped some but not enough. I beveled the lower rear deck( may come back to haunt me) and carved some notches into part of the rear hull plate.
Now the upper hull fits correctly on the lower hull and I glued the two together. (another hind site piece of advice, I would not glue the upper hull until after I glued the parts that fit on the front of the upper hull) I now glued the rear hull tabs back on and I see I will need to fill in the gap that remains. If you have used this rear deck conversion, what did you do? Did yours fit fine and I missed the memo or did you have a better way?
