I wouldn't even assume that Befehlstigers had only one single layout.
David
Blimey, I bet you're the life and soul of the party.....
David
Hey Mirco,
for a second I thought you suggest a Tiger Normandy Built Campaign on this Side...I would join that in a second.
While I can't help with any of your questions, I can help you out with another Rye Field Interior. I love the Rye Field Kits for the outside Details but never use the inner Life.
Best,
Stephan
Quoted TextI wouldn't even assume that Befehlstigers had only one single layout.
David
Now it's your turn folks. What do you think?
The private website TIIF.DE has been sorting Tiger photos for years.
They reckon this one is 233.
As for 214, they have three photos of it. It had;
Steel wheels
Front hull cutouts
A spare track pole across the lower hull front
The 40mm turret roof
No "Pilze"
The large muzzle brake
The reworked hinge on the escape hatch (one bolt removed)
In other words, 214 was from near the beginning of the Late batch.
David
2. As you can see on certain pictures, the Tiger I turrets received 2 kinds of Zimmerit. One with the same Zimmerit width as the hull and another one with wider Zimmerit pattern on the turret sides. Why is it so? Was it a change during the production run which you can date back to a certain date or was it just put on simultaneously in one and the same factory.
In some cases, several months elapsed between the first appearance of a modification and the time that it was present on all new production Tiger IIs. This was due to 'last-in, first-out' tendencies. This was caused by the storage of a shipment of newer parts which covered, buried or made inaccessible the stockpile of older parts....The Tiger II (Fgst. Nr. 280101, produced in July 1944)...has turret number 280110 which was mounted close to the correct sequence. However, the Tiger II (Fgst. Nr 280243, produced in September 1944...has turret number 280093, which should have been mounted on a Tiger II produced three months earlier. (No, it wasn't changed after capture, the correct numbers are on the original turret serial number plate. (page 18)
Quoted TextQuoted TextI wouldn't even assume that Befehlstigers had only one single layout.
David
I shouldn't worry. True to form.
Every forum has at least one I suppose. Pity really....![]()
Gentlemen, be polite,
please.
I may decide to trim/prune this thread if it goes further off the rails![]()
/ Robin
I would anyway, there's a certain amount of deliberate belligerence going on!
...says the first person to post an off-topic insult.
To claim that parts are from "007" is a huge claim, and it increases their price by a factor of probably five. I think anyone who makes that claim, or passes it on from someone else, should be subject to questioning.
And asking questions about the Tiger parts is within the topic of this thread.
David
