Building a 1/16th. Scale M5A1 Late Stuart
Posted: Friday, July 10, 2020 - 11:40 AM UTC
Really enjoying and appreciating your building of this model.
ironhull
KitMaker: 134 posts
Armorama: 134 posts
Posted: Friday, July 10, 2020 - 04:38 PM UTC
The 30Cal. Mgs. aren't much better, ...
Donald
I bought the Aber metal barrels. A bit expensive but they are a nice addition. My MGs had what like a small palstic sinkhole on the body, not really evident but a littel annoying.
Bye
OldWarloke
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Saturday, July 11, 2020 - 09:15 PM UTC
The Hull is painted & Bogies are installed.
(Note) Be shure all the wheels line up, or you'll have trouble fitting the track.
I'll be working on the track next while waiting for the Shape-ways Mg.s
Donald
Donald
mariuszbiel
KitMaker: 20 posts
Armorama: 20 posts
Posted: Monday, July 13, 2020 - 11:46 PM UTC
My Aber barel:
OldWarloke
Posted: Wednesday, July 15, 2020 - 03:35 AM UTC
The Aber Gun barrels look nice, but I have the Shape-ways guns ordered and expect delivery in the coming days.I'll post a pic. when I get them.
Donald
Donald
OldWarloke
Posted: Wednesday, July 15, 2020 - 03:39 AM UTC
Now on to the Track, and how I assembled it.
I don't say this is the only way, it's just how I did it'
First off you need 65 Track Shoes for each side with 5 pieces for each Shoe, That's a lot of parts to clean up.
I glued the Guide Horns to the connectors , this eliminates the chance of getting glue on the shoes.
OldWarloke
Posted: Wednesday, July 15, 2020 - 03:49 AM UTC
This should be self-explanatory
OldWarloke
Posted: Wednesday, July 15, 2020 - 03:54 AM UTC
OldWarloke
Posted: Wednesday, July 15, 2020 - 04:00 AM UTC
The following Pic. is from the Squadron Walk-Around book showing the double cleat on the shoe leading the single larger one.
I'm not shure if this is correct or if it really mattered.
The book states that this track type was not really common and that the Stuarts usually used a rubber block or chevron type of track.
I'm finished for a while.
Donald
OldWarloke
Posted: Friday, July 17, 2020 - 01:44 AM UTC
KurtLaughlin
KitMaker: 2,402 posts
Armorama: 2,377 posts
Posted: Friday, July 17, 2020 - 11:51 AM UTC
Do the tracks have any keying to keep the pattern running in the same direction? I could see finishing a run, sitting back, and noticing the grousers pointing in different directions.
The most common tracks, by far, were the T16 rubber blocks with the T36E6 a low second. The rubber chevron T44 and all-steel chevron T55 appear mainly on M5 tractors.
Other three-bar-grouser tracks are designed to be installed so that as the tank moves forward, the single bar hits the ground first.
KL
KL
OldWarloke
Posted: Saturday, July 18, 2020 - 02:14 AM UTC
KL
There's no keying, the track should be assembled with the inside down, there's a small recess where you put the glue, and it's up to you using the Mk.1 Eye-Ball to get them all facind in the same direction.
See Pic. #115 above, this is from Squadrons Walk Around Book, it shows the top of the idler with the track going over it. If you look closely you can see the double cleat leading the large one so that when they touch the ground the small ones will touch first.
I just went by this pic. I don't know if this is correct or if it really mattered.
OldWarloke
Posted: Saturday, July 18, 2020 - 02:18 AM UTC
Now for some Turret and Gun work.
I hinged the Turret Hatches.
This was fairly easy as the hinge parts that go on the turret top are separate parts, and it's just drilling through the centers of the hinges and the centers of the hinge area on the hatches.
Be shure to place the hatches on the turret top before gluing the free part of the hinge to the turret top.
OldWarloke
Posted: Saturday, July 18, 2020 - 02:29 AM UTC
finished for now.
Donald
OldWarloke
Posted: Monday, July 20, 2020 - 05:46 AM UTC
I just received the Mg.s from Shape Ways, It's kind of hard to tell how good they are , with them being made in a translucent material.
Hopefully they will be better than the kit Mg.s
I ordered a set of 5 Three for this build with 2 left over for the 1/16th. Sherman that RFM is working on.
Still working on it.
Donald
Donald
OldWarloke
Posted: Tuesday, July 21, 2020 - 11:05 AM UTC
Here's the Gun painted with Model Master Gunmetal.
The other side
Mounted coaxialy , I only glued it at the back end to allow for movement when installing the Mantlet.
The other side
OldWarloke
Posted: Tuesday, July 21, 2020 - 11:11 AM UTC
OldWarloke
Posted: Tuesday, July 21, 2020 - 11:16 AM UTC
Interior was previously painted white, now it's masked to paint the outside.
I have a lot of little parts to add to the inside.
Finished for now.
Donald
Finished for now.
Donald
ironhull
KitMaker: 134 posts
Armorama: 134 posts
Posted: Tuesday, July 21, 2020 - 05:13 PM UTC
What? A 1/16 Sherman? Please have you any other details about? I never heard anything about.
I don't like these Shapeways MGs. Lot of layering as usual for SW resin print and the barrel (the most visible part) is not better then the kit's ones. I think the new LED 3d printer could do a better job for the MG'sbody.
Aber barrels are still the best choise.
Thanks again for your pictures and comments about this nice kit.
Bye
Pierantonio
OldWarloke
Posted: Wednesday, July 22, 2020 - 05:22 AM UTC
Here are the Turret interior Pics. it didn't come out really good, but keep in mind, except for the radio you'll not see much of it.
OldWarloke
Posted: Wednesday, July 22, 2020 - 05:26 AM UTC
I'm getting tired.
Donald
OldWarloke
Posted: Monday, July 27, 2020 - 12:26 AM UTC
Ok , I'm finally finished with this build.
I'll be posting the Pics. so please be patient with me.
Donald
Donald
OldWarloke
Posted: Monday, July 27, 2020 - 12:27 AM UTC
OldWarloke
Posted: Monday, July 27, 2020 - 12:31 AM UTC
OldWarloke
Posted: Monday, July 27, 2020 - 12:36 AM UTC
Now for some Detail Shots.
