Well,
I was ready for the worst, being my first resin kit, but I found it quite easy to fit.
the underside of the deck is a bit rough and I had to use a small chisel and files to remove material from the channels where the academy hull goes.
Some trimming had to be done in order to install it leveled and a litle warping of the deck was solved with a strong ciano glue.
Quite frankly it was better than I expected.
The wheels are very nice but some of them have flash on the holes and I cut the holes under a magnifying glass with a very sharp xacto.
The only thing that is less bearable is the resine dust and the smell (oooh the smell...
). I cut the excess on parts with a dremel disc and even at low revs I get covered in dust...
But as I go along I can see that this is going to be a sweeet Merkava...
I have to find a way to install those balls and chains without getting mad :-) :-)
