I have been working on fixing the shape of the Tamiya Lee turret which is way off with Milliput. Don't know if it is 100% accurate, but seems alot better than before. I added a rope used for infantry handholds particular to Lee's in Burma. Also, I added the three bolts seen on the turret top along with another larger bolt/plug? which shows on some pics. I used a 37mm barrel from Jordi Rubio and added the gyro-stabiliser balance under the cannon. (Tamiya instructions shows this as a machine gun mounting which is incorrect). Since the cannon sight is molded in a position which would have the cannon pointing skyward, I hollowed this area out and made a new opening out of brass and styrene so the cannon can point in a more straight forward manner. I also filled in the area under the cannon with Milliput since it seemed too large a gap.
I also detailed the inside of the turret lid and scratchbuilt a smoke launcher for the left side of the turret.
Well, that's all for now. Thanks for looking.
