Them one color things are kind of hard.
You,ve got that right, Bud!
Anyways, here's a small update.
Quite a challenge to paint these mono colored vehicles.
Here's some pics after the first three transparent coats of OD and two transparent coats of OD mixed with Tamiya Sky in a shade I thought looked ok. I tried to apply the lighter shade of color along the edges and where the light would fall naturally. I used a lamp as a "sun template" in front and slightly elevated over the vehicle to notice the highlights when airbrushing.
Then I airbrushed two coats of MIG filters, first Green for Light Green and then Grey for Bright Green. I applied the grey to try and fade the OD even more.
I then made a mix of Abteilung Faded Grey and Odourless Turpentine and brushed it over the entire vehicle. Left this to dry for a while and used the same mix and a flat thin brush on edge to make some rain streaks, you can barely see them on the turret here. More of these streaks will be applied when the weathering starts.
I decided that the vehicle should belong to the "Tiger Division" 20th Armored Infantry Battalion, 10th Armored Division in Germany spring/summer 1945.
I put the decals for this unit on with Solvaset and I think I steered clear of the dreaded silvering.
I then mixed an even lighter green shade and brush painted the parts sticking out on the vehicle like filler caps, hinges and so on. Not very visible in the pics but it's there.
Well here she is now with decals, another filter coat of Faded Grey filter and a Vallejo Air satin clear applied.
I'm now starting the tedious process of painting the stowage and detaling the lower hull so I recon it will be some time until the next update. Cannot say that I'm looking forward to painting all that stowage in the back, hopefully I'll pull it off.
When that's done the real fun begins...weathering!
Bare with me on the pics, I've got some weird problem with my cam so they are kinda blurry.
