Armor/AFV: Canadian Armor
Discuss all types of Canadian Armor of all eras.
Canadian ISAF Coyote
sauceman
KitMaker: 2,672 posts
Armorama: 2,475 posts
Posted: Tuesday, November 16, 2010 - 01:17 PM UTC
Looks great Rick....A piece of trivia....the vent and brake line covers are a decendant of ones originally produced for the AVGPs back in the late 1980s.....I guess someone finally got tired of replacing the lines after they got ripped of while bush bashing.
Yes it sure was a welcome modification LOL.
cheers
gcdavidson
KitMaker: 1,698 posts
Armorama: 1,563 posts
Posted: Tuesday, November 16, 2010 - 01:58 PM UTC
Rick, the turned wheels really add a lot of impact. Did your RM set not come with resin wheels though?
sauceman
Posted: Tuesday, November 16, 2010 - 02:45 PM UTC
Thanks Graeme, yes it did, I just used the kit wheels for mock-up
cheers
BLACKWATER
Yunnan, China / 简体
KitMaker: 449 posts
Armorama: 441 posts
Posted: Wednesday, November 17, 2010 - 12:59 AM UTC
Production process is very exciting, I will always be concerned about it.
Blackwater
sauceman
Posted: Wednesday, November 17, 2010 - 01:40 AM UTC
Blackwater
Groovy, glad to have you along
cheers
PeterPL
Poland
KitMaker: 73 posts
Armorama: 69 posts
Posted: Wednesday, November 17, 2010 - 08:35 AM UTC
Extremly good work. PE looks great.
Looking forward for updates
Cheers from Poland
sauceman
Posted: Tuesday, December 14, 2010 - 01:50 PM UTC
Thanks Peter!
Had a little more time at the workbench today
Mainly worked on the muffler and heat shield. Added the missing exhaust pipe (I think it's for the crew heater or coolant heater) from brass tube and spare mesh. Also added some grab handles from brass wire and finished off the brake and hub vent lines.
Until next time!
cheers
vonHengest
KitMaker: 5,854 posts
Armorama: 4,817 posts
Posted: Tuesday, December 14, 2010 - 05:54 PM UTC
This looks like it's coming along nicely, and good job with the PE, I'm still having a hard time folding large flat pieces without warping them somehow.
Anirudharun
KitMaker: 597 posts
Armorama: 530 posts
Posted: Tuesday, December 14, 2010 - 11:31 PM UTC
Sweet build Rick, its coming together really well! I'll be following this one as well.
Would you mind posting a close up of the brake lines? I presume they are a similar layout on the ASLAV as well.
Thanks
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Tuesday, December 14, 2010 - 11:53 PM UTC
Some very detail oriented work here Piotrek. I have just recently started working with PE and am now having to fork out the extra money for the tools.
sauceman
Posted: Friday, December 17, 2010 - 01:39 AM UTC
Thanks, for the larger PE parts I like to use a hold & fold.
Thanks
Thanks, when I get a chance this weekend I will post up the brake and vent line schematics for ya
Thanks, since the stash is well stocked i'm concentrating my purchases on tools and equipment, the right tool can turn a PITA project easy peasy in a hurry LOL.
Question, does anyone make a 25mm ammo box in PE?
I'm trying to replicate this exhaust shield found on some Coyotes.
cheers
retiredyank
Posted: Friday, December 17, 2010 - 02:34 AM UTC
Everything I could find along the 25mm pe ammo boxes.
http://www.greatmodels.com/~smartcart/cgi/display.cgi?item_num=AZP35375
It's not pe, but the crates can be assembled open or closed with ammo visible.
sauceman
Posted: Friday, December 17, 2010 - 03:25 AM UTC
Thanks for the help, but those are WW2 wood crates, I'm looking for the modern steel ones as used currently.
cheers
ti
Dalarnas, Sweden
KitMaker: 2,264 posts
Armorama: 1,763 posts
Posted: Friday, December 17, 2010 - 04:24 AM UTC
Fantastic looking build.
recceboy
KitMaker: 706 posts
Armorama: 665 posts
Posted: Friday, December 17, 2010 - 04:47 AM UTC
Rick
Looking good and makes me want to break mine out and start.........
cheers
Anthony
gcdavidson
Posted: Friday, December 17, 2010 - 05:46 AM UTC
Rick, you should be able to make that ammo can out of spare PE bits.
Are you doing all the sensor stowage bags along the side of the hull?
sauceman
Posted: Friday, December 17, 2010 - 06:11 AM UTC
Thanks Charles!
Rick
cheers
Anthony
Thanks Anthony, no time like the present
It's sure looking like that's the direction i'm going to have to go.
As far as the stowage my plan is to replicate this particular Coyote that I photographed in KAF during my tour, so yes i'm going to make the sensor stowage bags. I have no idea as of yet how, but that's the plan.
cheers
recceboy
KitMaker: 706 posts
Armorama: 665 posts
Posted: Friday, December 17, 2010 - 05:04 PM UTC
Rick
That Yote is a Mast version with all of the bags.
Anthony
sauceman
Posted: Saturday, December 18, 2010 - 02:07 AM UTC
Rick
Anthony
Yep, and no i'm not building the sensor suite LOL.
cheers
sauceman
Posted: Saturday, December 18, 2010 - 08:56 AM UTC
Here's the drawings for the brake lines;
cheers
retiredyank
Posted: Saturday, December 18, 2010 - 09:04 AM UTC
Looks like you have a bit of scratchbuilding ahead of you. I'm sure all the details will make this an impressive build.
shopkin4
Illinois, United States
KitMaker: 1,135 posts
Armorama: 1,030 posts
Posted: Saturday, December 18, 2010 - 12:53 PM UTC
Rick,
Can you use those brake line drawings on an LAV A2? If so, then check the build logs tuesday
sauceman
Posted: Saturday, December 18, 2010 - 01:24 PM UTC
Rick,
In theory yes, but those diagrams are for the Canadian Coyote specifically, so I cannot say for certain.
cheers
sauceman
Posted: Sunday, December 19, 2010 - 12:10 PM UTC
Got a little more time at the workbench today
Wasn't happy with the muffler mounting and heatshield so I modified the pipe comming out of the hull by drilling a hole in the hull and the coresponding hole in the muffler. I also had to trim away a little of the moulded on up-armour for it to fit better.
The muffler and heat shield fit better now.
Added all the bolt heads on the front plates.
Finished off the right side as well, except for the odd grab rail.
cheers
sauceman
Posted: Wednesday, December 22, 2010 - 03:14 PM UTC
Tonights work centered around the blast shield around the air sentry hatch.
The instructions are a little vague but I was able to figure it out. I ended up using the clear cover from a CD case for the glass
I also added some detail with the hatch locks, the one on the hull and the ones on the sides of the blast shields.
comments and critiques welcome!
cheers
