Hey Stefan and gang!
I fully intended to join this campaign months ago but have been busy with house renovations and writing reviews. Anyway, with time running out and a bit more spare time, I finally signed up.
Some super work going on here and even though not an active participant I have been dropping in from time to time. Here's my choice for my entry, the trumpeter Pershing.
With the recent Kitmaker downtime I decided to start this weekend. For a small scale kit it sure has enough sprues and parts.
I started at the back of the hull and don't necessarily follow the kit's construction sequence. The instructions aren't too bad but there was a bit more flash than I've recently experienced with other kits.
The rear most road-wheel suspension arm on the right side was broken in the box. It's going to take some ingenuity to reattach it but I'll worry about that later.
Next I put together the sprocket drive housing pieces. The didn't fit all that well and took a fair amount of sanding.
The return rollers are two piece affairs and had a sloppy fit. Since their are a five a side this took some time.
Started adding the suspension arms and again, the fit wasn't the best. A couple of the holes had to be enlarged and the locating tabs are a bit too small for the slot they fit into but I got them all on yesterday.
Not the fastest progressing kit but it's at least starting to look like something.
Hopefully the rest of the build goes a bit smoother.
Jan
