Armor/AFV: Canadian Armor
Discuss all types of Canadian Armor of all eras.
LAV III Trumpeter repair& build
seb43
Paris, France
KitMaker: 2,315 posts
Armorama: 2,158 posts
Posted: Sunday, October 03, 2010 - 11:59 AM UTC
Milo
Just to be sure
The conversion will be a Lorit one, not an upgrade version of the LAV-III with rear and turret blast shield ones since I can see the fuel tank armor as well as the rear hull armor ??
What will be the contents of the kit then ??
Seb
seb43
Paris, France
Posted: Sunday, October 03, 2010 - 12:02 PM UTC
Milo
So in one word:
What will be the difference between RM 35214 and RM 35215 ??
Seb
bulivyf
Praha, Czech Republic
KitMaker: 2,450 posts
Armorama: 2,409 posts
Posted: Saturday, October 16, 2010 - 04:14 PM UTC
Milo
So in one word:
Seb
Seb
35214 is set for update LAV IIII. Include PE parts, resin parts, two figures and wheels.
35215 include PE baskets and some details for LORIT.
Miloslav
bulivyf
Posted: Sunday, October 17, 2010 - 04:36 AM UTC
After a long pause, I add a new update. I finished the rear spare wheel holder. It must be said that this is the first part of the perfect model. I added a Blast Shield on the back. I had to extend the parts yet because I use parts of the LAV III (for AFV model). Backside Blast Shield and I will add a new set.
Now I will prepare turret. I have a dilemma whether to use the kit turret of my products or just add instructions for repair and new covers. The Turret from Trumpeter has incorrect rear upper armor, but the turret version with the blast shield must be removed.
Then just replace the main periscope to be correct, and the aforementioned covers.
More photos.
http://www.realmodel.cz/index.php?option=com_content&view=category&layout=blog&id=41&Itemid=85
LeoCmdr
KitMaker: 4,085 posts
Armorama: 3,917 posts
Posted: Sunday, October 17, 2010 - 05:07 AM UTC
Very nice work Miloslav...impressive update.
Can you offer both turret upgrades to the modeller?
One including your turret if they aren't going to mount the blast shields and one using the kit turret with just the corrections and covers? If the modeller is going to be removing the kit rear upper turret armour anyways then just included the corrected parts.
bulivyf
Posted: Sunday, October 17, 2010 - 05:17 AM UTC
Thanks Jason,
Yes, I prepare and repair Turret from Trumpeter. Maybe I'll do two versions of the new set with no turret and turret. I do not want to set expensive.
Miloslav
sauceman
KitMaker: 2,672 posts
Armorama: 2,475 posts
Posted: Sunday, October 17, 2010 - 10:54 AM UTC
Nice update Milo!
I agree, the more parts that can be used form the original kit the better.
cheers
AirOps
KitMaker: 25 posts
Armorama: 24 posts
Posted: Wednesday, October 20, 2010 - 04:00 PM UTC
Milo,
When can we expect this kit? I am eager to get started!
bulivyf
Posted: Wednesday, October 20, 2010 - 06:50 PM UTC
Milo,
Now finishing up a proposal to the PE parts. I would have prepared two sets of one or two weeks.
Brad-M
British Columbia, Canada
KitMaker: 402 posts
Armorama: 393 posts
Posted: Friday, October 22, 2010 - 08:40 AM UTC
So I guess Trumpeter really goofed on this one? I was contemplating getting one, but not if I need to spend as much or more for corrections. Oh well...I guess it depends on how bad I want a correct one on the shelf.
Brad
AirOps
KitMaker: 25 posts
Armorama: 24 posts
Posted: Friday, October 22, 2010 - 04:27 PM UTC
Hi Brad,
Listening to the armour guys at the last meeting it isn't that bad of a kit and can be built into an early Afghan machine from the box.
But I build so little armour I plan on dressing this one up so I plan on these sets.
bulivyf
Posted: Sunday, October 24, 2010 - 08:51 AM UTC
Turret update:
I used the Trumpeter turret. I cut off all washers and bolts. Then I did the anti sleep surface and glued new correct screws and washers.
I adjusted the rear top of the add-on armor because it is manufactured as one piece, not two parts.
Since the thin armor on the turret, is not necessary to remove the installation Blast Shield.
Here is the problem shows that the hull is shorter by 4 mm. Therefore, the rear basket reduced by 2-3 mm. Turret must be rotated.
I added the correct antenna mount and periscopes.
More photos:
http://www.realmodel.cz/index.php?option=com_content&view=article&id=92:lav-iii-trumpeter-step-by-step&catid=41:work-in-progress-&Itemid=85
sauceman
Posted: Sunday, October 24, 2010 - 11:29 AM UTC
Thanks for the update Miloslav,
Are you going to add the turret blast shields?
cheers
recceboy
KitMaker: 706 posts
Armorama: 665 posts
Posted: Sunday, October 24, 2010 - 11:58 AM UTC
Milosalv
Well done with the conversion working on Trump's Lav-3.
Anthony
seb43
Paris, France
Posted: Sunday, October 24, 2010 - 02:48 PM UTC
Great Great Job Milo
Are you going to add the T-antenna at the rear of the hull ???
Seb
AirOps
KitMaker: 25 posts
Armorama: 24 posts
Posted: Sunday, October 24, 2010 - 04:20 PM UTC
Looks awesome Milo!
sgtsauer
#065
Missouri, United States
KitMaker: 2,605 posts
Armorama: 1,814 posts
Posted: Sunday, October 24, 2010 - 05:48 PM UTC
Great work Miloslav....
bulivyf
Posted: Sunday, October 24, 2010 - 06:56 PM UTC
cheers
Thanks Rick.
Yes I add to the turret Blast shield which will be in PE set.
Miloslav
bulivyf
Posted: Sunday, October 24, 2010 - 06:59 PM UTC
Seb
Seb
Set include T-anntenna but I for this version this don't use.
Miloslav
bulivyf
Posted: Sunday, October 24, 2010 - 07:01 PM UTC
Anthony, Gary & Brent,
Thanks in your commended.
Miloslav
bulivyf
Posted: Tuesday, November 02, 2010 - 10:09 AM UTC
Last update.
Now the model is complete as the version from 2008. All Resin & PE parts, which includes photos of the new set of RMA 35214.
We will continue building LORIT version where'll use parts from the new set RM 35215.
Left side. Here, no tool box, because the left side is ready to LORIT large basket.
recceboy
KitMaker: 706 posts
Armorama: 665 posts
Posted: Tuesday, November 02, 2010 - 10:16 AM UTC
Milosalv
Another Master build, very well done, now that look like a LAV-3. Lots of work really paid off.
Well done
Anhtony
bulivyf
Posted: Tuesday, November 02, 2010 - 10:22 AM UTC
Milosalv
Well done
Anhtony
Anthony,
Thank you for the comment.
Miloslav
seb43
Paris, France
Posted: Tuesday, November 02, 2010 - 10:36 AM UTC
This is great great addition for the LAV-III.
Congrats Milo
It was worth waiting.
I have my LAV-III plastic kit reayd for this one.
Seb
sauceman
Posted: Tuesday, November 02, 2010 - 11:20 AM UTC
Nice work Milo!
I have put my LAV III on hold waiting for this, good stuff!
cheers
