BMD-1 Skif
Spiderfrommars
Milano, Italy
KitMaker: 3,845 posts
Armorama: 3,543 posts
Posted: Thursday, September 01, 2011 - 01:08 AM UTC
Hi all
A little time ago I started to build the BMD-1P kit produced by Skif
It was very cheap indeed (It cost me 15 €, about 21 USD) but when I bought it, I really didn't know about its quality. Checking the sprues I was very pleased to notice that the kit is quite good, more than I expected from an eastern Europe kit. Of course, it doesn't have the same quality of the latest chinese releases, but it doesn't have any flash and seems to depict in a quite convincing way shapes and dimensions of the original vehicle. In the box you can find also a little PE fret, but it looks quite rough so only few of their parts actually can be used. Kit gives singular track links, which are a little simplified but accettable.
Eduard produces a set for this kit ( http://www.ecomodelismo.com/bmd-1p-Ref-EDUA-35517.html ), but I've decided not to use it so i'll make some scratch build to improve the model
Regarding the original vehicle, you can find short information here
http://en.wikipedia.org/wiki/BMD-1
If you'd like to read a review of the kit you can look here.
http://www.internetmodeler.com/2002/december/first-looks/skif_bmd-1p.htm
Russian army has deployed the BMP-1 and BMP-1P (which is a varian of BMP-1 with a 9S428 ATGM or a 9P135M-1 ATGM rocket launcher mounted on the turret ) in Afghanistan, durung the Second Checen war and in South Ossetia campaign. As usual with my projects, I've collected a lot of reference pics from eastern sites but to be honest I haven't decided yet what will be my exemplar.
As the first step I modified the hupper hull. According to my reference pics, there were some mistake which I corrected using plastic card and putty
Some details looked too crude such as the periscopes. I removed them opening some loopholes. In those holes I'm going to insert new scratch made details.
Regarding the rear deck, Skif has reproduced it with details which are too raised and sharp. I sanded down them ans i replaced the bulges with plastic card details. It was quite a nightmare but I'm quite stisfied with the result
Skif rear deck
Actual rear deck
Rear deck modified
As you can see I also hopened the grills holes and rebuilt the grill frames. Skif offers photo etched grills, but they are simply awful, so I think I'll replace them with fine metal mesh.
My job so far
Any suggestions and helps will be greatly apreciated.
I'll post other steps soon
(Ps pics have been posted for discussion purpose only,)
Nito74
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Thursday, September 01, 2011 - 02:15 AM UTC
I did that one years ago... it cost me around 10 € which was a real bargain.
But the kit was quite hard to put together.. the tracks are awful and also fitting the upper hull with the lower tub.
I wished I picked the Zvezda version...
It looks your getting a good job out of it so far !!
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Thursday, September 01, 2011 - 02:32 AM UTC
I recently trade a MTLB by Skif. The quality was ok. I did have a problem mating the upper and lower hulls. However, I used masking tape to bend the upper hull so that it would mate with the lower hull. Put it back in the closet and a few weeks later the hulls mated perfectly. My biggest complaint is the general lack of detail found in Skif's kits. I'm sure that, with a little detail work, it will build into a fine model.
Spiderfrommars
Milano, Italy
Posted: Thursday, September 01, 2011 - 06:29 AM UTC
Well I've already done some fitting trials. There's a large gap between upper hull and vertcal sides, but anyway there are no details in that zone so it wouldn't 'be difficult to fill it with plastic rods and putty.
However for a such low price, some fitting issues is the least I could expect On the other hand the kit is made with a plastic rather "soft" so, as Matt said, matching the parts using elastic bands and masking tape would be enough to obtain a decent result.
Thanks a lot John
cheers
Spiderfrommars
Milano, Italy
Posted: Thursday, September 01, 2011 - 09:35 AM UTC
Hi all
Another small update
I've done the rear grills. According to my reference pics they look a little bit raised
To replicate them I've used a dense wire metal mesh which I bought a while time ago in a hardware store (...Actually I love using cheap materials for my builds... )
As the first step I've stuck with double sided adhesive tape a piece of plastic card on my workbench. Plastic piece was 2mm thick and it had the same dimensions of the rear grill holes ( 10,5mm X 16mm)
Then I put the wire mesh on the plastic piece...
...and using a wooden coffee stirrer, I've deformed the wire mesh untill it was perfectly adherent to my jig...
Then using a pair of small scissors I've cut the wire mesh excess...
That's my final result:
I haven't glued yet because I haven't reproduced the blades which are under the grills.
I hope you like it
(Ps pics have been posted for discussion purpose only.)
jointhepit
Oost-Vlaanderen, Belgium
KitMaker: 3,829 posts
Armorama: 881 posts
Posted: Thursday, September 01, 2011 - 11:24 AM UTC
yippe, great postin Mauro!
got a Zvesda cloon half finnish in a box, but seeing your improvments and how to, I'm thinkin of getting out the saw and file and start altering mine following your lead
thanks!
17741907
Istanbul, Turkey / Türkçe
KitMaker: 953 posts
Armorama: 705 posts
Posted: Thursday, September 01, 2011 - 11:52 AM UTC
Good start Mauro....
orpant
Attica, Greece / Ελλάδα
KitMaker: 139 posts
Armorama: 135 posts
Posted: Thursday, September 01, 2011 - 08:15 PM UTC
You're off in a prominent start Mauro!!!!!
Looking very good!!!
I'll follow the build with interest!!!!
Spiderfrommars
Milano, Italy
Posted: Thursday, September 01, 2011 - 08:28 PM UTC
Many thanks to all of you for your interest and for the kind words
I hope i'll be able to post other updates after this weekend. At the moment I've been removing some anaesthetic mould seams from the vertical sides...and it's quite annoying
Hi Pit
Zvezda BPM is slightly different from the Skif kit. Its hull probably is easier to build because it has less pieces so there will be less problems about the alignments Unfortunately it has also (ugly) vinyl tracks ...but you told me that is half finished so you've aready known
Anyway I'll be glad to see your model...and if you need references, let me know
Cheers and thanks again
SHarjacek
Croatia Hrvatska
KitMaker: 977 posts
Armorama: 553 posts
Posted: Thursday, September 01, 2011 - 08:37 PM UTC
As always Mauro,very nice!
Spiderfrommars
Milano, Italy
Posted: Thursday, September 01, 2011 - 08:56 PM UTC
Hi Sven, how do you do mate?
Thanks a lot!
Karl187
#284
KitMaker: 3,094 posts
Armorama: 2,942 posts
Posted: Friday, September 02, 2011 - 01:03 AM UTC
Hey Mauro- I see you are really go to town on this! Fantastic detail so far and great references too. The work you've done with the rear deck and the rear grilles is simply inspiring.
I'm going to go have a close look at my Eastern Express kit to see how the detail in these areas compares.
Good luck with the rest of the build mate. Oh, any thoughts on paint schemes yet? How are the decals in the box?
bison126
Correze, France
KitMaker: 5,329 posts
Armorama: 5,204 posts
Posted: Friday, September 02, 2011 - 01:46 AM UTC
Really nice additions so far Mauro !
Keep on the good job
Olivier
Spiderfrommars
Milano, Italy
Posted: Friday, September 02, 2011 - 03:09 AM UTC
Thanks a million guys your very kind indeed
Olivier, I know the you've already done this kit. I hope I'll be able to do a very good job like yours. Thanks for the interst
Karl, thanks a lot...regarding your questions ...
I haven't decided yet. In our opinion what would be cooler ?....
Afghanistan:
Ossetia
Chechnya
KFOR
Uknown unit
Some of them are the first BMD version vithout the grills on the front glacis, so to depict one of them I'll have to modify the model
Decals look decent but to be honest I haven't tried yet
Cheers and again many thanks to all of you
bison126
Correze, France
Posted: Friday, September 02, 2011 - 05:19 AM UTC
Mauro,the Skif Kit depicts a 1P that is with a Spigot ATGM launcher not the early Sagger ATGM. So if you decide to go with the Afghanistan war, I think you'll certainly have to modify the main gun too.
Some with more expertise than I may pop up and correct me if necessary.
Olivier
Karl187
#284
Posted: Friday, September 02, 2011 - 05:45 AM UTC
Mauro- I'm probably going to go with either the 2 or 3 Color KFOR paint scheme when I do my BMD. There are so many schemes to choose from for this vehicle! You could paint it Russian Green and then weather the hell out of it. Then there is that interesting scheme they had in Ossetia with the grey in it. So much choice!
I took a look at the Eastern Express kit and the rear deck appears to be the correct shape, or a better approximation of the correct shape, than the Zvezda kit. Unfortunately the rear grilles are moulded as small ridges on the EE kit and will likely need more work than the Skif kit.
Anyway, waiting for your next update bud, good luck!
Spiderfrommars
Milano, Italy
Posted: Friday, September 02, 2011 - 09:54 AM UTC
Olivier
Yes Olivier that's it.
Anyway on the reference pics it seems that rarely rocket launcher were installed, so I don't know if I'll put on my exemplar eventually
Here some reference with caption translation
http://otvaga2004.narod.ru/otvaga2004/armour-rus-bmd/a_bmd1p.htm
BMD-1P reconnaissance 317-th DMA 103rd Airborne Division. Afghanistan, 1985
Airborne reconnaissance unit on the BMD-1P in Afghanistan, 1985
Look at the T-62 fuel tanks on the rear deck
Soviet BMD-1P in Afghanistan
Anyway, waiting for your next update bud, good luck! here
Yes Karl, Ossetian exemplar looks attractive indeed ... I have also a pic which depicts Russian exemplars on a practice field which are wearing an outstanding temporary winter scheme
Regarding EE kit, as far as i know is quite good, probably is better than the Skif kit. It has extra fuel tanks and its track links are depicted in a better way than the skif ones. Solid grill is a minor flaw which you, who are very skilled indeed, could easily correct in my opinion
Other exemplars:
Karl187
#284
Posted: Saturday, September 03, 2011 - 12:56 AM UTC
I forgot about that winter white scheme actually, thats not bad. More options!!
And yes, I must say the individual track links in the EE kit are very good- a little soft in some areas but adequate nonetheless.
Spiderfrommars
Milano, Italy
Posted: Saturday, September 03, 2011 - 04:11 AM UTC
As usual "studying" reference is the most important thing to do
Doing that I've noticed that I have to be carefull if I decide to reproduce an Afghan BMD.
In fact some of the BMD used during the afghan war were the early series so they had different wheels
Early wheels
Mid series wheels (1980)
Late BDM-1 P wheels
Karl, Winter scheme is my favorite so far
cheers
seanmcandrews
KitMaker: 561 posts
Armorama: 553 posts
Posted: Monday, September 05, 2011 - 04:33 AM UTC
Mauro,
where did you find those technical drawings, great stuff!!
Sean
Spiderfrommars
Milano, Italy
Posted: Monday, September 05, 2011 - 05:37 AM UTC
Hi Sean
Although unfortunately I don't speak Russian, when I do Google searches about eastern stuff, I allways use keywords written in Russian. It allows me to find more information, a lot more than those which I could find using English keywords
Anyway you can find interesting drawings and pics here
http://vadimvswar.narod.ru/ALL_OUT/TiVOut0809/BMD-1/BMD-1002.htm
http://vadimvswar.narod.ru/ALL_OUT/TiVOut0809/BMD-1/BMD-1001.htm
http://army.lv/ru/bmd-1/701/58
http://www.army.lv/files/98.pdf
I hope this is usefull for you
cheers
Spiderfrommars
Milano, Italy
Posted: Tuesday, September 06, 2011 - 05:38 AM UTC
Hi
Some small upgrades here
According to my reference pics, on the sides of Bmd there's a sort of circular hatch
In Skif kit, this circular hatch looks raised, so I've decided to remove the original detail and engraving a new one.
First of all I made a jig using dymo tape. I holed the tape using a belt punch
I put the jig on the model and I engraved it using a sharp punch
Then I washed the engraving, putting on it a very light coat of Tamiya thin glue
This is my final result
I 've also made two scratch details to simulate the lamellas which appear under the rear grills
I haven't glued them yet. I need your suggestions and I'd like to know your opinion. Should I paint the lamellas before closing the hull or will it be enough painting them at the end with my airbrush ?
Anyway, looking for other reference pics, I've found another interesting exemplar which I could replicate
Many thanks for our interest
SHarjacek
Croatia Hrvatska
KitMaker: 977 posts
Armorama: 553 posts
Posted: Tuesday, September 06, 2011 - 06:16 AM UTC
Very nice and crative Mauro,good work.
+1 for winter camo .
Emeritus
Uusimaa, Finland
KitMaker: 2,845 posts
Armorama: 808 posts
Posted: Tuesday, September 06, 2011 - 06:34 AM UTC
Looks great! Very neat scratch-building you got going on.
Keep up the good work!
On your question about the lamellas under the screens, I'd recommend painting them beforehand. The screen is quite fine and mostly likely you'd have very hard time getting the parts behind the screens evenly covered without cloggin the screens with paint.
Spiderfrommars
Milano, Italy
Posted: Tuesday, September 06, 2011 - 06:50 AM UTC
@ Sven
Thanks a lot mate. So far winter scheme it's my favorite
@ Eetu
Yes, I think you're right, although mesh are incredibly fine i think it would be probably better painting them before. At least i think i have to paint them with primer
Thanks a lot for your advise and for the kind words
cheers
